C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Strange day working on car, ALWAYS monitor AFRS
Old 08-01-2015, 08:31 PM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
Default Strange day working on car, ALWAYS monitor AFRS
So was on the way home from cars and coffee in the vette, doing some highway pulls when I noticed it leaning out bad after 4k RPM. Would go from mid 10s to mid 17s on AFR. Did it a few times getting out of it quickly. Watch Fuel pressure and it would go from 60psi to 30psi. Ugh, looks like only 1 of the two fuel pumps is working.
So I get it home, pop hood and check fuses. Both good, both have voltage. Pop rear wheel and fender line off, check voltage at the relays, all good, 12.5V on each. I pull one fuse and start the car, starts fine. Pull the other, no fuel pressure. So identified which one isn't working. So I then swap relays, no difference. Then I jumped the one good one across the + to the fuel pump wire, and it kicks on, do the same for the other, no go. Then I jumper from the good line to the "bad" pump and it kicks on just fine. Strange. Run a wire from battery to that line, kicks on just fine. Check voltage again, relay and line is getting 12.5V but it won't get on even when jumpered. So start checking everything.
Start replacing wiring/etc going from relay foward to alternator. Replace main wire, even though it measures good, no go. Replace fuse and fuse holder, no go. Finally replace the ring terminal on the end, and bingo, all good. I have no idea, but the ring term volt'd out fine, had continuity, but for some reason wouldn't pass enough current or something to run the pump. Replace the ring terminal, all good.
So lesson learned, always monitor FP/AFRs on a big build or big fuel syste. If I wasn't paying attention, that couldn't have easily been a melted motor.
Old 08-01-2015, 08:56 PM
schpenxel
schpenxel's Avatar
Received 1,194 Likes on 1,053 Posts
St. Jude Donor '15
Stuff like this is why it blows my mind when some people don't run any gauges whatsoever. Dash logic is awesome though.. I'm assuming you were using it but perhaps not.
Old 08-01-2015, 09:15 PM
Unreal
Unreal's Avatar
Actually didn't have it in the car at the time. Was using the aeroforce since it is on the pillar. Typically use that just because it fills the hole in the pillar, even though I like the dash logic more, just haven't got around to messing with it.
Still don't get how pump had 12.5V but wouldn't kick on. Ohh well.
Old 08-01-2015, 09:29 PM
djfury05
djfury05's Avatar
Not like this is something new to monitor. No point in having the gauges if you aren't going to look at them.
Old 08-01-2015, 09:56 PM
neverstop
neverstop's Avatar
damn! close call. a/f and fuel pressure gauge both seem like "must have" to me on these cars. honestly i always think its funny people put on boost gauges before a/f or fuel pressure as if i had to choose just one gauge i'd always choose the a/f guage to prevent nuking motors. it's always super strange the weird little quirks these cars seem to develop when taken to this extreme.
Unreal, I think your car is probably the most frequently driven >1k whp setup on this board so always interesting to hear how the setup is doing also as an example of things we can watch out for.
Old 08-01-2015, 09:59 PM
Unreal
Unreal's Avatar
Agreed. I've never looked at boost gauge. I don't care what it says.
AFR would tell me I have an issue, and it did. FP told me what the issue was.
Old 08-01-2015, 10:06 PM
realcanuk
realcanuk's Avatar
St. Jude Donor '13
Glad you caught it in time. This is why I watch my aeroforce constantly and also have alarms set.
Old 08-01-2015, 11:55 PM
MARSC6
MARSC6's Avatar
Was there corrosion or anything on the ring terminal? Doesn't take much to cause trouble when dealing with low voltages.
Old 08-02-2015, 08:49 AM
GeneSch
GeneSch's Avatar
Can the DashLogic report back AFR? If so what is the code to do this. I would love to have the dashlogic report this and not have to add the AME wideband.
Old 08-02-2015, 10:20 AM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
You have to add a wideband regardless.. the stock O2 sensors aren't capable of reading accurately except right around 14.7:1 (which is normal for narrowband O2's), which won't do you much good at WOT
You can connect an output from the wideband controller to dash logic then display AFR on the DIC or HUD. Some wideband controllers have gauges that you can then either ignore or also install, others are just a box and have to be connected to something, i.e. HP Tuners, EFI Live, Dash Logic
So.. it's def. possible to put it on Dash Logic (that's how mine is setup) but you'd have to add the wideband either way
Old 08-02-2015, 10:32 AM
JetstreamGS
JetstreamGS's Avatar
Good catch. I just installed a PLX in mine. When driving normally and I let off to shift, it jumps crazy lean. Is this normal?
Old 08-02-2015, 10:36 AM
Unreal
Unreal's Avatar
Didn't look too closely. Very well could have been. Already tossed it.
Yes a dash logic can monitor and warn off WB02, just need to wire one in. I plan to keep the dash logic in full time whenever i pull my a pillar gauges, but been too lazy to do all that, so sometimes I run it, because it rocks, and sometimes I just run the aeroforce.
Yes, when you let off car actually cuts fuel. Decel fuel cut off (DFCO) is very common and almost all new EFI cars do it. No reason to spray when when the motor is just slowing down.
Old 08-02-2015, 10:38 AM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
Manual or auto? Stock tune or something else?
May be clutch fuel cutoff which cuts fuels during shifts (normal) if it's an M6
Or it could be transient fueling not being quite right, which pretty much no one gets right and isn't perfect from the factory
Either way, wouldn't worry about it.
Old 08-02-2015, 11:24 AM
JetstreamGS
M6 blown and cammed.
Good to know. Wasn't too concerned about it but thought it was strange as it always does it when shifting.
Old 08-04-2015, 10:14 AM
5 Liter Eater
5 Liter Eater's Avatar
St. Jude Donor '11
Nice troubleshooting. Most shops would have just started throwing parts at the problem. LOL
Old 08-05-2015, 06:29 PM
Unreal
Unreal's Avatar
Sad but true. Most shops would have had a $2000 fix by replacing pumps and wiring.
Old 08-07-2015, 11:49 PM
90zcrex
90zcrex's Avatar
When checking with multimeter the meter doesn't put a load on the circuit, so the bad connection at the ring terminal was just enough to carry the tiny load the multimeter needed to read 12v, but once you put the load of the pump on it, then all your voltage goes away.
Good job on the troubleshooting, just remember to always check voltage with load applied to circuit.
To Strange day working on car, ALWAYS monitor AFRS
Old 08-08-2015, 12:55 PM
Boat Racer
Boat Racer's Avatar
Old 08-08-2015, 10:17 PM
BLOWNBLUEZ06
BLOWNBLUEZ06's Avatar
Nice catch!
I must say even with gauges, it's often difficult to watch them as power increases. 1400whp and I find myself watching the road and the tach because it comes around so quickly.
With the Haltech Elite, I'm able to set shut downs or add compensation based on whatever circumstances I choose. It's really nice to have.
Old 08-08-2015, 10:53 PM
winters97gt
winters97gt's Avatar
Ask me how I know.
Quick Reply: Strange day working on car, ALWAYS monitor AFRS
