S480 Fender Mount C6Z06 Stock Bottom End 800+WHP
Received 1,194 Likes
St. Jude Donor '15
Nice!
I'm curious what it looks like from the front with the hood down?
that looks freaking MEAN! did you say what intercooler you used? how are IATs and how responsive does this setup feel when cruising around? curious if you could post the whole dyno sheet also? I'm interested to see what the torque curve looks like compared to my D1SC 427ci setup with similar power.
St. Jude Donor '15
Yeah, that looks awesome.
Yea it's actually not that expensive to replicate because the piping isn't running all the way to the rear of the car. The spool up is so loud from the drives seat. Who knows it might suck the hat off someone's head when they count off for a run lol.
-Curtis
#33
For sub 1000hp, a 2" crossover pipe on each bank is sufficient. Nice looking build.
#34
Thanks, here's pics from up front
Anyways guys I decided to upgrade one of my fuel pumps, going form AEM 380lph to a Grams 440lph E85 inline pump. I'm pretty excited to change it out since now changing pumps is a breeze without the OEM saddle bag style tanks.
Unfortunately for me one of the AEM Fuel pumps decided to Crack on me, I'm unsure how
I'm going to try and contact AEM to see if I can get another pump to replace this defected one. The other pump is fine.
-Curtis
#35
It's ok
Mines are 3 inch but I personally wouldn't go any tighter then 2.25 at least with a 7.0L lol.
-Curtis
-Curtis
Louis Gigliotti (09-21-2015)
#36
Looks very good. I have a pretty good log book of testing with the LS platforms over the last 15 years. My last combo was a 450"(7.37liter) LS on methanol(M5), MSD promag44 ignition with a 118mm(1.50 turbine) that had 1 7/8" headers and a 2.5" crossover made little over 3x the power. Turbos want velocity before the turbine. It definitely takes alittle to digest. I have always sized the hot side pre turbine for peak RPM/VE/Boost so the combination is optimized at full tilt out the back door. On a side note who did the fabrication.
-Curtis
#37
Wasn't there a big thread on yellowbullet on this? I know Phil was in on that, but most can see the size of the turbine housing volute is tiny and it not making a lot of sense to step up to a huge pipe just to neck down again.
I love the idea though OP, nice to see different things in here. I often wonder if I really needed to run a full heavy exhaust if the car is just for fun.
#40
