S480 Fender Mount C6Z06 Stock Bottom End 800+WHP
This should be the Highest Whp for a stock bottom end LS7 as far as I know. Here is the mod list. Fuel is E85.
LG Motorsports G7XX Camshaft/ LG Cam kit
Wcch stage 2 Milled .130* 13:8.1 Compression
Stock LS7 Manifolds
160* thermostat
Stock Throttlebody (Ported)
Holley Hi Ram Intake Manifold
Mcleod RXT w aluminum flywheel
ARP Studs
ID1000cc Injectors
Fuel Lab adjustable FPR
Twin AEM 380lph in line fuel pumps pulling from a fuel cell
TurboBay Performance Billet S480 T6 1.58AR
Car was tuned by Darin Dichara@DoubleDtuning
Setup was built by Matthew Coleman@SpeedZone Kissimmee FL
6psi of boost and 10* timing
Prior numbers were 623/545 when the car was N/A
6psi from the TB Performance S480 netted 837/741
Watch "C6 Z06 S480 13.8.1 compression 6psi" on YouTube
Stock LS7 Manifolds
160* thermostat
ARP Studs
ID1000cc Injectors
I had the same head porting and milling done to mine when it was N/A. Can't believe someone is throwing boost at it too! Interesting build for sure
Edit: nice STD corrected numbers too btw. That still puts the car at the 800whp mark approx.
-Curtis
Thanks man and for putting up with my questions when I was trying to hit 600+ N/A lol. I just wanted to try something different. Pretty much took an all motor setup and slapped a turbo on it.
I'm definitely going to build a motor in a couple months. Probably run 2 s480's or go with a single 106 or 118mm
-Curtis
-Curtis
Your car sounds wicked on the dyno! Nice to see someone pushing the stock bottom end into the 800rwhp range. Good choice of fuel too. I run E-85 on my nitrous setup. Hard to detonate, it's a nice buffer to have.
-Curtis
-Curtis
