Problems with pistons breaking help!
#41
#42
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,082 Likes
It's actually a timing belt to be exact, or at least that's how it's listed. Just like a timing belt, when set up correctly they last a long time.
__________________
C5/C6 and C7 Supercharging Specialist
ECS Supercharger Kits / Mantic Clutches
www.EastCoastSupercharging.com
Facebook Page
ECS YouTube Channel
Facebook Page
ECS YouTube Channel
#43
Please read my post above yours, you do not need to purchase a pulley!!! Especially a grooved pulley with holes in it like posted before. They wear out belts much faster and you will have zero problems with belt slip with out once we get you all fixed up.
You have an alignment issue that I will be glad to assist you with. Please PM me your phone number and I'll give you a call to discuss in length.
#44
Yea we know its a cogged flip.. Not blower like this..
They even stated at the show "who the fk cogs anymore!?"
#45
I'm pretty sure your shop knows what kind of timing and AFR are appropriate for our 91 octane --but if they installed and tuned the thing, I'd expect some thorough testing to make sure everything is working as it should.
What do you have for a fuel system? ECS BAP? Has it been verified that's it's working right?
#46
either there is something else to the story here I am missing or could be bad injector possibly or maybe, and long shot but only other thing I can think of, is I've heard of people having coolant leaks causing air bubbles causing hot spots in the cylinder and blowing stuff up, but I'm really really reaching here. also could be fuel pump on its way out not showing it on the short dyno pull but on the street on a long 4th gear pull the pump can't keep up.
you really need to get a wideband though, those thing should be required with FI vette kits imo
op, i'm sure the shop you're working with can diagnose this for you and get it right, they know way more about LS cars than just about any normal person you'll come across.
#47
And I couldn't agree more on the wideband. Should be a requirement.
#48
I think it's crazy so many tuners "tune" cars without doing any street tuning too, not sure what this shop did but street tuning on these FI vettes should be required, cars perform SO much differently on the street vs. dyno.
#49
Streek and neverstop'
The did mention something about the 4th gear long pulls and the last time i drove the car I did 2 up to 5th gear pulls...
Injectors seem fine and the afr is reading 11.2.
Ecs BAP system.
Ecs BAP system.
#50
#51
Depends on dyno. If a tuner is using a loaded dyno setup properly, then the difference is very small. If they are using an unloaded dyno, then yes.
#52
I see what you mean but for street cars I think there are a lot of variables for the tuner aside from just WOT where it takes some street time to get just right like all the driveability stuff. I'm sure most good tuners can get 90%+ of the way there on a loaded dyno but I really prefer to have my tuner spend some time on the street for all the random other driveability stuff.
#53
The problem is that you don't really know whether the AFR is 11.2:1 on something like a 5th gear pull. It might have been showing that on the dyno when it was getting tuned, but that doesn't mean that's what it'll be when making a long, hard pull with a hot fuel pump. Without a wideband on board, you really have no idea. Commanded AFR does not always equal actual AFR on these engines. That's open-loop fueling for you.
#54
Received 1,193 Likes
St. Jude Donor '15
Indeed. Add a wideband at the absolute least
#55
I got my car back and had the power reduced alot.
But I've noticed that the tranny and coolant and oil temps all shoot up to 230 F on a hot day...
Pretty scary why is that.. Thats a firsty
#56
I'm not sure how hot you mean when you say "hot day", but if you take a look at this section of the forum you'll see a bunch of threads related to cooling on these builds. It was about 90 here today in SB, so I wouldn't be surprised if it was even warmer down where you are. Have you driven the car in similar weather and traffic conditions, or is this the first time in this heat with the blower?
#57
St. Jude Donor '15
He's only driven the car like twice since getting the blower
Just kidding man!
Just kidding man!
#59
