TT Vette Build
Yes, I would have preferred a gen 2 block, but it already took convincing from the wife to sell the LQ4 block I was going to use and upgrade to the LSX block.
Man, you couldn't pay me to build a first gen LSX. I'm in the process of building a new engine for a friend who's first gen LSX cracked the sleeves in #1 and #3.
Best of luck with it though.
An option is to have the LME dry deck process done to it. Basically plugs are machined and pressed in to make it stronger before decking/boring it. But skip the O-rings.
Unfortunately, with blocks, as most things, the we tend to only hear the negative stories. Think of all the commotion that is out there about ERL blocks being trash, people cracking RHS blocks, etc. I've spoke to about a dozen shops who really specialize in LSX engines and no one seen a damaged 1st gen block roll though their shop.
Appreciate the heads up though. We shall see how she does
It was built in 2012 and had <1000 miles on it, no idea where it was cast. It was a 427 making ~1000 @ ~25# via a TTIX kit.
I hear what you're saying RE: only hearing the bad stuff. But GM saw enough failures like this that they felt the need to redesign the block. So it wouldn't be my first choice for a >1k RWHP FI build.
Received 1,194 Likes
St. Jude Donor '15
I wouldn't bother on a TT build.. just get a regular one if you change it at all
I'm using the C2501 model from Summit. It's < $200 and has held up fine on my supercharged application, so I expect it will be fine for you too.
Same here. I had a Powerbond on my LS2 that held up perfectly. Was interested in hearing opinions if an ATI was worth 2x the cost.
Small update this far. Unfortunately the pistons where delayed that put everything back a few weeks. After a lot of back and forth, I decided to go with a -11cc dish to bump the compression up to 10.2:1 instead of the mid to high 9's that I was shooting for in the past. Since the car is only mostly going to see e85, I don't really see too much of an issue.
Anyway, block has been cleaned up and bored out. Still needs the align-hone to be complete, but all the parts are now in.
Further more, pistons are a thing of absolute beauty
The following 2 users liked this post by staticki:
Arctic Vette (12-05-2015),
IMXCITD (02-19-2016)
Forged Pistons make me happy.
#33
St. Jude Donor '15
Those sure are pretty
#39
There are a lot more than 2 versions of the LSX block. Mine doesn't have the reinforced water jackets. It was 1-2 months before that came out. Still almost 14k miles now at 1000+ with zero issues. Unless you are going 4.185, pinging the hell out of it, or 1400+hp I don't think you will even come close to an issue. I've seen plenty of "gen 1" later model blocks make 1500+hp for a long long time.
#40
Well I'm not saying 1st gens are made of glass, but I think that's an overly pleasant picture to paint.
And I'm not aware of lots of versions aside from deck heights and finished state.
