500ci RHS short block
With the option of lower compression. Its compatible for a supercharger. The question is is the stroke to big? Would it hold up? What's everyone's thoughts?
http://m.ebay.com/itm/NEW-500-CUBE-LSX-ALL-ALUMINUM-SHORT-BLOCK-KIT-100-AMERICAN-CRANK-WISECO-RODS-/291057625405?nav=SEARCH
Damn youre goin hard bro, 800hp NA then add boost.. Lol, i havent seen anything on this block FI but NA it went 201 in the Texas mile with MTI and they are on this board..
IMO, no reason to run a tall deck block for a forced induction application. Adds too many complications, and added expense. There is a reason all the fast fast LSX cars are not running them.
Waste of money.
Stay with the 427 ERL bro..
He has 2200R and he will run the 2.85 close to 20psi
Because to get that CI out of a tall deck LSX block you have to move the wrist pin up, run a huge stroke, and a thin piston. They don't have the bore spacing to run a 500+ci setup like a big block.
When you have 427 based LS motors making 2500+hp, why mess with what works?
Received 1,194 Likes
St. Jude Donor '15
Hasn't RHS had problems with blocks cracking once they're really pushed? Maybe it's not applicable to this one or been fixed by now? I know Bret's cracked and I know joe whatever his name is has cracked several. He's running a solid block now last I read, no water jackets (race only, obviously)
After a lot of researching I would just do LSX. I wouldn't touch ERL.
St. Jude Donor '15
Curious why not on ERL?
Seen WAY too many issues with them recently. Find a way to msg me besides PMs on here if you want the story.
The purpose of a tall deck it to be able to run thicker crown pistons with longer strokes. OP, I'd call and experienced tall deck engine builder.
Unreal, mind messaging me, or PM the ERL horror stories you've been seeing lately?
I'm very curious since they're one of 2 shops I'd consider to sleeve blocks.
A good friend of mine had a issue with his ERL block and another guy I'm acquaintances with.
Basically the same as Detoxx. Issues after issues, and when you really start asking around it seems more common.
