What is this
What is this
Hey guys doing the blower install and I've got a few pics of an item. Just wondering if it's the extra idler for the A&A second drive system or if it's part of the A&A ysi supercharger kit. Thanks for your help
Only place i could see that is ac idler but i could be wrong..
Yeah that's what I'm thinking. Josh said he was now putting in additional idlers with their second drive kit to eliminate the problem they have with the second drive kit not holding enough tension over time. So I'm assuming that's it. Now the question becomes where do I mount it.... Well here's where I've drilled the holes in my block!!! What do you guys think.
Platinum Supporting Vendor
Lee that is correct. It's the extra idler for the C6s and yes you drilled the holes in the correct spot to mount it. Give me a call if you need any help with it or anything on the project. -Josh
Hey bud thanks for the reply. We are installing everything on the motor except for the actual blower now. The engine is going up through the bottom. Looks like everything will clear except for the head unit.
