injector help needed
I was trying to install my new injectors this afternoon and the connector is different than the stock injectors. Am I missing something?
Was sent 107962 60lb injectors.
Received 1,193 Likes
St. Jude Donor '15
Yeah, there are adapter harnesses to connect about anything to about anything else.. so I'm sure that's all it is. My ECS ones came with adapters but I didn't end up needing them. I thought the LS2/LS3 connectors were the same but I guess the injectors you have are an older style connector
St. Jude Donor '15
I think this is them? Not 100% sure
russ472 (11-19-2015)
Amazon.com: GooDeal® 8pcs Fuel Injector Connector Adapter EV6 to EV1 USCAR LS2 LS3 LSX LS1 LT1 TPI: Automotive
St. Jude Donor '15
