will a stock Ron Davis radiator fit a ECS car
I have a line on a used one and actually called Rod Davis and they said no. Doug Ill take you word as I am sure you have installed your kit with one. Anything special I know the plastic intake with the filter is really close. As always appreciate the input.
I have a single core DeWitts with spal fans. Stock fan settings for on and off plus more cfm's. Stock 180 thermostat.
Usually runs 189 unless stopped. Fans come on at the factory settings. Bolted right in.
