*** ECS fuel systems on black Friday special ****
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,081 Likes
We are passing along some savings to get your vehicle powered up properly with fast easy ordering from our web site link below.
We have also made improvements to our fuel system without increasing the pricing.
The fuel system comes with all lines made and pressure tested, so no making fuel lines at home or in the shop which means a much speedier install!
No running fuel lines from back to front of the vehicle, everything sits nice and tidy in the rear of the vehicle. Stealth, yet very effective.
Our filtered fuel block means no drilling and tapping a plastic fuel tank. We have proper seal that will not leak or weep fuel.
We now use an AEM fuel pump which is E85 compatible and flows even more the the Bosch pump we used to use.
This system lets you have the fuel supply you need with no dropping of the fuel tank for our stg 1 system, and no annoying loud fuel pump buzzing!
This savings is being passed to our distributors too, so if you are working a deal for a supercharger kit with one of them you can get this same deal threw them as well.
__________________
C5/C6 and C7 Supercharging Specialist
ECS Supercharger Kits / Mantic Clutches
www.EastCoastSupercharging.com
Facebook Page
ECS YouTube Channel
Facebook Page
ECS YouTube Channel
Received 1,193 Likes
St. Jude Donor '15
Are you using crimped ends on the hoses or regular connectors?
Glad to see ECS is assembling the lines prior to shipment. Makes for a much easier and quicker install. I battled with the lines and ended up making my own. This kit is worth the money. Much easier than dropping the tanks.
I don't think that is the case. At least when I purchased mine it wasn't. The pics show the lines built but you have to assemble them yourself. It's an insurance issue.
St. Jude Donor '15
Their ad states they come assembled now. That's why I was asking whether they were crimped or not
St. Jude Donor '15
I am still wondering whether they are crimped or not.
It's really not a big deal either way, I was just curious..
We can't get the bends we need in crimped lines, a 90* bend won't fit in the crimping machine. So we would either need an erector set of fittings or std style hose ends.
Our issue was that insurance wise we could not make the lines and send them out without a 10k a year binder and well we just don't sell that many fuel systems, but we found a manufacturer that makes the lines and pressure tests each one prior to sending them out to us.
So the hoses now come assembled and pressure tested.
Thanks, we did not like sending the hoses unmade either, it was just a matter of circumstance that we had to over come.
This change is very recent, sorry if you did not fall in that time line!!
