2.5" Hotside turbo pipe enough for 1000rwhp?
My quest to make 1000rwhp has yet to be achieved. And im uncertain my current set up will allow me to make 1000rw.
My build is an 05 6 speed twin turbo c6.
-408 stroker * iron block * 9:1 cp
-Dart 250cc heads
-stock ls2 intake / TB
-1300+ fuel system
-Mcloed rxt
-UPP TT kit
-Twin 61/82 bb turbos
-2.5" hotside piping
-Dual Nozzle meth
So my issue i think im going to have is back pressure due to the 2.5 hotside piping. The downpipes are also 2.5" which will be dumped at bellhousing.
I recently dyno tuned the car on a dyno jet with my old set up which was an aluminum 408 with 57mm turbos, it pettered out at 800rwhp/ 805rwt. Although i am upgrading to slightly larger turbos do you guys think my piping will be a big restriction ?
Im still putting car back together after the engine swap so if i need to change some stuff now is the time to do so although my budget is about tapped out.
-Dart 250cc heads
-1300+ fuel system
-Mcloed rxt
-UPP TT kit
-Dual Nozzle meth
-Dart 250cc heads
-1300+ fuel system
-Mcloed rxt
-UPP TT kit
-Dual Nozzle meth
-Dart 250cc heads
-1300+ fuel system
-Mcloed rxt
-UPP TT kit
-Dual Nozzle meth
Have you measured back pressure?
What turbine wheel/ housing you have?
Lots of depends as well from the turbine side/ housing But the truth will be you definitely have there on that power level back pressure issue due to small(?) turbine wheel/housing and down pipes/ and exhaust is too small if 2,5".
From the manifold to the turbo does not need to be 2.5". 2"-2.5" pre-turbo isn't going to be the restriction, the turbine housing will be. Although my setup is very short I used 2" ID piping to my v band housings and had no issue cracking 1000whp under 20psi intake pressure. A lot of the faster single turbo drag race guys might run a 2.5" crossover on a 1500-2000hp setup, but using that large of piping on a lower power setup will just add lag. Velocity is where it's at pre turbo, Yellowbullet has some good info on this topic if you wanted to read more.
-Curtis
2" pipe flows way better than the smaller t3 turbine housing. With the length of his piping I'd run 2.25", but I know the kits are built with 2.5". Guys making light years more power than us are running 2.5" pre turbo. I don't feel displacement plays as much of a role as overall power output, but I have a 383 and 6265 t3 .82 housings.
http://www.yellowbullet.com/forum/sh...d.php?t=308464
-Dart 250cc heads
-1300+ fuel system
-Mcloed rxt
-UPP TT kit
-Dual Nozzle meth
-Dart 250cc heads
-1300+ fuel system
-Mcloed rxt
-UPP TT kit
-Dual Nozzle meth
What size inducer and exducer is the turbine?
What AR is the turbine scroll?
The 62mm exducer turbos should really have a 1.0 AR to Crack 1krwhp. Great example was the z06 aps kit, not the base c6 kits.
The 65mm can do this with 0.82 AR etc.
I would keep the 2.5" pre turbo since the outlet on the manifolds are 2.5" no point to neck down to a 2". You will have no lag or issues with the 2.5.
Post turbo I would put as big as you can fit.
Former Vendor
Keep the 2.5" Up-pipes, swap the down-pipes to 3". It's a proven setup and there's multiple people now that have cracked the 1K mark with that setup. 2.5" down-pipes would be a struggle, hence why we redesigned the kit to now have 3" standard and allow for the bigger turbos.
CK
CK
I'm measuring example both side back pressures and exhaust pressures, compressor side pressures, 8X egt's, 8X LSU 4.9's plus down pipes two more, Motec Level 2 1000hz logging.
Most backpressure issues people talk about are completely turbine housing/wheel size driven. Exhaust after the turbo can add a tiny bit, but it's nothing to what is pre turbine.
Correct, I think the biggest problem in Corvette is the space issue for turbo sizing, people looking for too high power levels with too small turbos (turbine side)= lots of issues, back pressure problem etc. Okay, works fine at 1/4 mile and street but make several full mile pulls after mile pulls on airfield is huge risk get failure, my opinion.
Former Vendor
But I also agree with the point that properly sized turbos for the application helps dramatically. From my experience most people aim too high. Twin 90mm T4 turbos to make 600whp.
CK
