EX1's Procharged Build - v2.0
#41
Received 1,194 Likes
St. Jude Donor '15
Looks nice!
#42
Well the first obstacle has finally popped up. The machine shop said there were some casting issues with my specific LSX block and they weren't comfortable using it. Luckily they had another one there but they have to start over again. Fingers crossed it is done soon and with enough time for the start of the 1/2 mile season here in Texas.
On a positive note, my Brodix BR7 heads arrived. WCCH used their CNC program on them and they look great!
#43
-Curtis
#45
Had some light scoring on the pistons I was planning on re-using. Machine shop said they were fine but I ended up ordering some new Wisecos for this build. They are expecting around 10.0:1 compression and I will be back to the standard 4.125 bore. New pistons should be here in 3 days
Shopped around for a while and ended up ordering the F1X today from Colorado Speed. After having the polished finish on my F1R, I couldn't just settle for the standard satin. I know some guys don't care but I really think it helps the blower "pop" at the shows I take the car to. I was thinking about trying the new black powder coat, but I was scared it would get scratched or chip from mishandling, especially when doing a quick belt change in between rounds at the track .
#46
We actually have to ship everything halfway across the US, to get this coating, (and then back) to get this kind of quality. Each item's surface gets a special prep done to it as well, to make sure the coating "sticks" to the billet/alum. as much as possible.
So yes, many people coat/paint their blowers. But I would be hard pressed to think anyone is doing it to the level that we are. (Just another carry over from our Industrial devision)
#47
sub'n
I just did a ERL 427 turbo rave extreme with a very similar rotating assembly with 6 bolt Brodix BR7 heads from WCCH. Car wouldn't make more then 987 rwhp because of the baby procharger intercooler so a procharger race version is going in. Car is pullied to 21 psi with a Procharger F1C and if the intercooler does not get me close to 1100 I will probably go the same route and go with a F1X. FORE triple pump, ID2000's, RPS triple, very similar to yours. I know once I see the power you get out of the F1X my 500 miles F1C will be in the classified section!! I can't wait to see the number!!!
#49
sub'n
#50
sub'n
Those are stout numbers on a 427 with an F1C. Must be that velocity stack
#51
sub'n
However, an F1C is not gonna get you 1100rwhp.. I'm surprised you made it to 987 rwhp. Even an F1R won't go 1100. You may as well order the F1X now.
Sub'd for the progress..
#53
He never mentioned which F1C he was running. Maybe it is one of the new F1C 10.5 units? Come to think of it, I haven't seen one of those on a Vette yet. I wonder how they do.
No way of knowing. I learned last year to not sign up for events and prepay before the car is 100% AND sitting in my garage. I lost over $900 in non-refundable fees from missing various races. I won't be doing that again!
#54
no experience with RPS but heard from buddies that used it that the engagement is like a lightswitch and they don't have a great life, i have mantic triple in my car and love it. very streetable and holds great and installs same as any other clutch. From what i've seen at all I have to recommend the mantic triple over the rps
#55
Feel I need to add some things in here, so here we go
The normal "HO" intercooler was never intended to be a race unit.
It is designed for 1,050HP worth of airflow. (AKA: At the crank)
Which is stated in our literature (that hardly anyone reads)
However to call it a "baby" is kinda unfair, since many people have swapped it out for our competitors units, and picked up power.
We then designed the "race" intercooler, to help push cars about as far as you would ever want to take an air to air intercooler, which is rated right around 1,500HP worth of air flow (again at the crank) And since cars like AMP's black car have laid down something like 1,400+ with this unit, thats pretty much well past it's design intention.
Anything past that, really should have an air to water. People would be surprised what happens to the aerodynamics of these cars as the car goes up in MPH. Its really hard to get any air "through" the intercooler, once the car begins to "push" the air under/over/around itself. The intercooler then just becomes a heat sink, nothing more.
As to be expected. Glad the results were as planned.
So stoked for your car
The F-1R was never designed to be the "end all, be all" blower.
Frankly it was really only designed for 1 class of racing, because that sanctioning body TOLD us what to build, because the Vortech/Paxton cars couldn't keep up.
Sadly it takes a pretty specific engine combo to make the F-1R work to its max potential, Really its a medium size motor (with amazing flowing heads/cam) and medium boost. (It was designed to run in a non intercooled class, and to have a very very flat boost curve)
The F-1C-10.5 is also a class specific blower, so no reason to go down that road either. The smaller F-1A-94 gets the job done just fine, or go to the normal "X" unit.
Hope this helps a bit.
#56
I'm eyeing the F1A-94
#58
So are you saying that the F1a-94 outperforms the F1C-10.5? How big of a difference does the 10.5 housing make on those blowers?
They certainly put up some good numbers. Jeff (turbotuner) liked the top end pull of his when he swapped but he did say it was a lot softer in the midrange compared to his regular F1A. It did help with traction but it felt sluggish enough for him to pick up a F1R and a F1X to try. If only he had tried more combos with thise blowers before he sold the car
Haha! Yellow and atomic orange were always my favorite
#59
to corey and cody....
F1X ALL THE THINGS!
_____________________
13' DIB GT - MPR Sleeved motor
FI - EDP Big Single - BW with Race Cover
Built 6R80 - PBH built, Circle D converter
Boost Management - via BoostLeash
Fuel - 1500's, full Fore fuel sys.
Hemi Grand Cherokee - DD/Tow Pig
F1X ALL THE THINGS!
#60
Again, if a customer is looking for a 10.5" housing blower, just get the "x" thats all there is to it.
The "a" and "c" are designed for stick cars in mind, with very robust midrange power curves.
The "a-94" is designed with power-glides in mind, and big stalled autos (AKA: it stays in its power band up top, who cars about the silly mid range the car will never be in) That is were the blower was designed to shine, and well... thats what it does. Destroys literally everything in its size class, hands down.
Fran at RPM just put a "a-94" on a C7Z with the A8 trans, talk about a deadly combo. That trans has such little RPM drop on the shift, it will be deadly with that blower.
