Overdrive crank dampers
#42
I guess they assume that if you're overdriving your blower on a LS7, that you're a hard core racer who has no use for A/C??!
So, to sum up, it looks like the only options for overdrive crank dampners (which is what this thread asked about, after all) for the LS7 or LS3 dry-sump (like the OPs car) with A/C are:
- IW 10% overdrive 8-rib;
- IW 10% overdrive 10-rib;
- Powerbond 10% overdrive 8-rib.
JetstreamGS (12-28-2015)
#43
What is the quality of the powerbond balancer?
Anyone running this as an 8 rib set up? How is the alignment?
It looks to be a one piece construction and that should eliminate it come ing apart like some of the IW balances have. But does it do a good job removing the harmonics out of the motor?
#44
It's manufactured in Australia (where they build lots of badass LS motors and parts) and I've read somewhere that Powerbond manufactures dampners for some OEM applications, but I'm not sure.
M M Alexander is running one, so maybe he'll chime and let you know whether he has the whole 8-rib setup.
GeneSch (12-28-2015)
#45
CI GS (12-31-2015)
#46
I'm not sure if ATI lists that in their super confusing chart, but the ATI rep said the dry-sump 10-rib was available with A/C in an 8" diameter. Why they don't offer it in 6 or 8 rib, I don't know, but it's still an option.
CI GS (12-31-2015)
#47
Received 1,261 Likes
fwiw, if you are interested in a specific company but they don't publicly offer the exact balancer you want you might try contacting them and asking if they can make what you want... it might cost a tad more since it's custom but they may be able to do it... I had my innovators west 10 rib balancer cut for 6 ribs on the ac side and I did the same on my secondary drive that way I can use a zr1 ac compressor and a 6 rib belt if the 4 rib ever gives me any grief... and the ls7 balancer that was mentioned above that had no ac option, I don't see any reason why they couldn't cut the ribs for the ac side as long as the material is there... if they won't do that it wouldn't be very hard for another machinist to do it for you
CI GS (12-31-2015)
#48
I've been running it on the new motor for about 9K trouble free miles thus far. It's an 8 rib balancer but I'm still running a 6 rib set-up. I'm seriously considering getting a direct drive from A&A - and running the blower with an 8" belt since all I would need other than the DD is a blower pulley. Not in a big hurry to do it though. Earlier this month it put down 720 on a Mustang Dyno - on a tune pretty much done by me ... PatG tweaked and worked his magic and final numbers were 749/667 thru the A6 - Mustang Dyno
https://youtu.be/xICN1Yz9Ovg
Those are some pretty damn impressive numbers, especially on a Mustang and with an A6!
The usual obligatory questions follow:
- What kind of boost are you making?
- Those numbers are with Meth, correct?
- Did you change the cam? If not, then that's even more impressive!
- Is it a stock A6 and did you change/are you changing the converter?
If I were you, I would leave it where it is for now and just enjoy it. That thing must be a beast!
#49
I concur ...
The cam is a 222/242 on 6../6.. on a 120 LSA - mild/tame - stock converter friendly - Trans is totoaly stock (outside of tuning by PatG). If/when it blows, I'll replace it with another stock unit.
So I went and purchased me something that I'm highly familiar with, easy as cutting cake to work on and fairly cheap to modify/replace broken parts on
A FOX Bodied Coupe
I've already converted to 5 lug disc all around, Staggered 17x9 17x10.5 tire set-up, Strange shock struts, AJE Tubular K along with a LS3 / 4L80e combo .. to be huffed on by a 76/78 hair dryer
My girl thinks it's the ugliest car on the face of the Earth ... which means it's perfect
I have a complete, in great shape Black interior, going to black out the entire engine bay, and all new weather stripping, window trim, lights ect.. The rest of the exterior I'm not concerned with. I'm thinking a nice grayish/black primer with a clear coat.
CI GS (01-03-2016)
#50
I'm in for seeing how long that transmission stands up. Im betting it will last with Pat Gs tuning though.
On the new project:
Now THAT is what I call a sleeper, and will no doubt be a good running mustang too!
Those old fox bodies run good, even with ford power, so I can only imagine what that will do with a boosted LS3!
On the new project:
#51
Here I am about to order an Alky Control kit. What other alternatives are available?
#52
My kit has been going for 3 years with no issues at all.
#53
Devils Own
Devils Own is priced better and the Owner is a good dude. He's out of Oklahoma - real easy to talk to/deal with. Julio is a pain to talk with in my experiences with him (and this goes back to my Mustang days in the early 90s )
#54
Wouldn't hesitate to use Alky Control. It's a shame that M M Alexander had a bad experience but that seems a rare occurrence. I don't hear of many problems and I'm pretty sure Julio would be there with support if one came up.
#55
I can only speak for my own experiences, but both of my Alky Control kits have been flawless. First one was on my car for 3 years and still running strong when I sold the car. Second one I've had on my current car for a little over a year. No issues with 100% methanol.
That's not to say there isn't some room for improvement with the kit. The electronics are bulky and aren't very modern, but they work. And after installing two of these myself, I can say that there is plenty of opportunity to have a poorly operating system if you don't really take your time with the wiring. The wiring is a bitch if you're OCD like me.
Short of building my own methanol kit from scratch, I can't think of a better overall C6 kit on the market. Not perfect, but pretty damn good.
#56
my alky kit has been great to me, going on close to 2 years with 100% meth at all times... the electronics could be a bit more compact to save space but my only gripe was that the lines did not look very good... I understand there is a reason behind the brass ends but I couldn't stand it... I ended up using nozzles and holders from devils own and I also moved my check valve to the pump end and had them make me a single line from the pump to my "Y" fitting and 2 small lines from there to my nozzles... I am not sure how devils own's electronics stack up but I don't like the plastic lines they use, although they could easily make you stainless lines like they did for me... as stated above, their owner is a cool guy and I had a good experience with him... both good companies in my experience
#57
Received 1,193 Likes
St. Jude Donor '15
I do wish their controller were a bit smaller and more advanced.. but it certainly is simple and works. The more stuff that gets added the more chance there is for people to screw up the settings
#59
#60
