Motor is out: Cam change or No? Eforce Z06
My daily driver '06 Z06 is going back together with forged pistons.
I am happy with the HP numbers near (700rwhp) and driveability.
Even the builder says it's not critical to change the cam but I'm wondering if a properly designed "blower cam" will add reliability for those top end runs one may embark upon from time to time.
I'm thinking cylinder pressure or something.
Otherwise, I want OEM manners in everything from heavy traffic to mountain roads.
Really could use some advice on this.
Thanks!
Thanks!
I would have a cam spec'd specifically for what you want. A smart "cam guy" will listen and give you exactly what you want. I used Pat G. myself, and specified that I wanted stock drivability, very mild lope, and of course maximum power under those conditions. I got exactly what I wanted from it.
speedz06 (02-01-2016)
Received 1,194 Likes
St. Jude Donor '15
If you ever think you might do one... now's the time
Former Vendor
It would make sense to do the cam now while your engine is being assembled.
Thanks!
Thanks!
How much is a Cam job only on ls3 grand sport
