ECS removing restrictor plate
I am currently running ecs1500, full catless exhaust, g6x3 cam, ECS stage 1 fuel...
Car made 624/543 on 93 pump gas no meth.
I'm getting ready to have the car tuned for e85 I was thinking of having the restrictor plate removed at the same time. Just curious if this would be a safe setup on e85 and what kind of gains can I expect?
Received 1,194 Likes
St. Jude Donor '15
What pulley is on the blower?
"Safe" is a bit relative when you're going to be pushing upwards of double the HP GM intended.. but plenty of people have done it before you with a remarkably low failure rate.
Obviously the tune is critical. E85 is awesome for making stock bottom ends survive.
Maxed out the 1500 blower is capable of somewhere in the 800's RWHP wise. Tune aggressiveness will play a big part in where you end up
St. Jude Donor '15
If you're upgrading injectors I'd go with ID1300's too...
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,085 Likes
My guess is 780 rwhp, let's see how close you get.
Up the injectors and make your stg 1 fuel system into our stg 2 by simply adding the block off's for the factory regulator while adding a boost referenced regulator. I can put a package price together for you if your interested.
__________________
C5/C6 and C7 Supercharging Specialist
ECS Supercharger Kits / Mantic Clutches
www.EastCoastSupercharging.com
Facebook Page
ECS YouTube Channel
Facebook Page
ECS YouTube Channel
will an ECS stage 2 fuel system supply 800whp of E85 fuel without any methanol kit? seems like might be asking more of that system than is possible. but maybe you guys have done this before with stage2 and e85
