Anyone running twin 6766s with V band inlets?
If so, what power are you making? What size motor? Which trans?
Trying to see if they can make 1100WHP through a glide without insane back pressure.
Ed (Slowride) used vband in/out T3 .82ar housings on his. Turbonetics cast wheel 62/65's, and made over 1k at wheels on corn. I would see 1100 being possible with billet 6766 precisions.
https://www.corvetteforum.com/forums...o-numbers.html
Keeping cubes down will help some, and can also dump the gates externally.
Or just go full retard T4 https://www.corvetteforum.com/forums...orking-on.html
Agree, not entirely apples to apples. Just a datapoint for reference using the housings you're asking about.
Precision is coming out with a 1.05 turbine vband housing. I'm not sure if the officially announced it yet, but we have them on order. They claimed we should see another 150-200hp out of the turbo.
I just called PTE and they said that housing for the smaller turbos isnt even close to being in production :/
He also said like I thought that the 6766 will be on the verge of 1100whp through a glide without insane bp. Kind of a gable at this point.
Seems like the Garrett GTX4088R would get you there with room to grow and has a v-band inlet/outlet turbine housing in 3 different A/R options.
I don't understand why more turbo companies aren't moving towards v-band inlets and offering larger A/R ratios.
Im ballin on a budget. Trying to keep cost down as mach as I can. Im doing a front mounted powerglide, and a ford 8.8 solid axle conversion as well.
Received 1,194 Likes
St. Jude Donor '15
What in the heck are you up to now
I'd use these up to 1200 on a manual I think, but you would lose more through the glide as you know. If it were on a smaller engine like a mod motor I'd say sure go ahead, but in this case it would be hard on stuff.
Tial or bullseye do v band housings also for different stuff, but they get pricy. I do know you could get a tial t3 v band 1.06 with a gtx setup.
I would not say all my power drop is turbo as those dynos were with a manual controller so boost would spike to 19 and slightly taper to 18 or less. I also only run 317 heads, ls6 intake and a 226 cam. Most of these cars will peak like that using this stuff unless you keep boost solid to redline. It is clear though that some backpressure is building and causing the loss up top. I just don't think they are done quite yet as the car was still making power. A billet 6766 seems like a lot of compressor to get through the turbine setup I use.
