C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
ECS 2200 Install
Old 03-18-2016, 10:26 PM
  #41
slow goat
slow goat's Avatar
Cam is out! Now, the reassembly can beginName:  photo642.jpg
Size:  1,009.4 KBName:  photo470.jpg
Old 03-19-2016, 08:25 AM
  #42
slow goat
slow goat's Avatar
Is a longer crank bolt needed for the IW balancer? Or is the stock length good?
Old 03-19-2016, 12:16 PM
  #43
DOUG @ ECS
Premium Supporting Vendor
DOUG @ ECS's Avatar
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,085 Likes on 656 Posts
A longer bolt is needed. It should have came with it?
Old 03-19-2016, 02:12 PM
  #44
slow goat
slow goat's Avatar
I bought it used. Anyone know where I can purchase one?
Old 03-19-2016, 02:15 PM
  #45
schpenxel
schpenxel's Avatar
Received 1,194 Likes on 1,053 Posts
St. Jude Donor '15
Found this
https://innovatorswest.com/960-Hardware.html
That bolt looks pretty cheap. Maybe it's different in real life.
Would an LS7 ARP bolt work?
Old 03-19-2016, 06:12 PM
  #46
slow goat
slow goat's Avatar
Originally Posted by schpenxel
Found this
I will research it. Can anyone chime in? I bought the balancer used which is why it didn't come with one.
Old 03-21-2016, 12:08 PM
  #47
slow goat
slow goat's Avatar
Balancer is in but I need a longer bolt. Any advice on where to get the correct one? Name:  photo564.jpg
Old 03-21-2016, 01:58 PM
  #48
corvettepower
corvettepower's Avatar
Ls7 arp bolt work great for me
Old 03-21-2016, 02:14 PM
  #49
schpenxel
schpenxel's Avatar
St. Jude Donor '15
Is that ECS kit different than the current ones? For mine the AC tensioner is connected to some of the supercharger bracketry.
It's much easier to install that part now while you have easy access.. so I would look into that. I'm not sure if you've messed with the supercharger parts or not yet.
Maybe your SC kit is different than mine since it's a bit older. Just a thought.
Old 03-21-2016, 04:48 PM
  #50
slow goat
slow goat's Avatar
I totally forgot about that part. This is what mine looks like :Name:  photo526.jpg
Old 03-21-2016, 04:53 PM
  #51
schpenxel
schpenxel's Avatar
St. Jude Donor '15
I would talk to ECS and see about getting the newer style tensioner and bracket. It is adjustable and you can use a regular ratchet to open it instead of having to use that tool they included in the box
See what they think
Either way that does get assembled to the lower passenger side of the timing cover.. probably easier to do now.
You also need to make sure the tensioner bracket you have is for an overdrive balancer if that's what you have. Otherwise the tensioner can hit the balancer and damage it if the belt ever were to break.
Old 03-21-2016, 05:24 PM
  #52
slow goat
slow goat's Avatar
See what they think
Actually, I have that one too! They sent it to me a little while ago. So, I will use that instead.
Old 03-21-2016, 07:29 PM
  #53
schpenxel
schpenxel's Avatar
St. Jude Donor '15
Good deal
Old 03-22-2016, 11:20 AM
  #54
DOUG @ ECS
DOUG @ ECS's Avatar
Take a look at the new bracket to make sure it is compatable with that tensioner. Our new tensioner (about 3 years in now +-) has two pins on the back instead of one.
Old 03-29-2016, 01:36 PM
  #55
slow goat
slow goat's Avatar
Quick update on the progress. The LS7 harmonic balancer bolt fit perfectly
Attachment 47967834
More to come soon.
Old 04-06-2016, 08:40 AM
  #56
darkknight91
darkknight91's Avatar
Attachment 47967834
More to come soon.
Slow Goat !...... after your done with the install, let me know if your interested in doing a cam swap on my blown ls3, I'm on the other side of US1 in the Gables
Old 04-07-2016, 03:55 PM
  #57
slow goat
slow goat's Avatar
That's not far from me. I'll let you know.
Latest pics. Awaiting some parts I ordered like a steam vent kit and a few bolts for the ac HD tensioner.
To ECS 2200 Install
Old 09-27-2016, 08:44 PM
  #58
UmX
UmX's Avatar
I made 772 on the ECS 1500 blower with my belt slipping.. I am upgrading to a 2200 not the R or X ver. i am hoping to break 900+ with it..Just not sure what the smallest pulley i can put on it..http://imgur.com/bv29fuz
Old 09-27-2016, 10:54 PM
  #59
slow goat
slow goat's Avatar
The build is complete. However, we are getting no oil pressure upon startup. We tapped the port next to the oil pump and used a garden sprayer to fill the motor with about 2 quarts. I suspect that I should have used oil priming port instead. I have ordered the fitting and will try again. Fingers crossed
Old 09-28-2016, 05:17 AM
  #60
GeneSch
GeneSch's Avatar
Attachment 48022426
Double check that you plugged you oil sensor wire back in. I had the same issue and it just wasn't plugged all the way in.
Quick Reply: ECS 2200 Install
