Everything you need to install a external oil cooler on your LS Series Engine.E
Former Vendor
St. Jude Donor '13
All 1997 to present LS-Series engines (Gen III/IV) with rear-sump oil pans including LS1/LS6, LS2, LS3, LS7, L76/L92/L93, LQ4/LQ9, and LSXNOT suitable for front-sump pans such as Pontiac GTO or Holden/Vauxhall Monaro oil pans
We have put together a package of all the parts you need to install an external oil cooler. No more hunting around to find fittings or hose or adapters.
This kit handles the cooling for 450-550HP
Kits Contains
(1) 9-series Setrab STD Oil Cooler
(1) 9-Series Setrab Oil Cooler Mounting Bracket
(1) Low Profile Low-profile oil cooler adapter block
(2) Black Anodizied -10AN Adapter Fittings
(2) 22mm - 10AN Cooler Adapter Fittings
(3) -10 AN 90 Hose Ends
(1) -10 AN 120 Hose End
10 Ft High Temp Stainless Overbraid -10AN Hose
Please Note assembly of fittings to hoses/fittings to cooler are required.
http://www.xplosiveperformance.com/0...AN_p_3258.html
05-13 CORVETTE C6/C6ZO6/GS 10-15 CAMARO SS/1LE/ZL1 SETRAB EXTERNAL OIL COOLER KIT -10AN PREMADE HOSES
http://www.xplosiveperformance.com/0...es_p_3301.html
05-13 CORVETTE C6/C6ZO6/GS 10-15 CAMARO SS/1LE/ZL1 SETRAB EXTERNAL OIL COOLER KIT -10AN THERMOSTATICALLY CONTROLLED
http://www.xplosiveperformance.com/0...ed_p_3304.html
05-13 CORVETTE C6/C6ZO6/GS 10-15 CAMARO SS/1LE/ZL1 SETRAB EXTERNAL OIL COOLER KIT -10AN THERMOSTATIC CONTROLLED PRE MADE HOSES
http://www.xplosiveperformance.com/0...es_p_3303.html
Former Vendor
St. Jude Donor '13
Kits Contains
Former Vendor
St. Jude Donor '13
Kits Contains
Former Vendor
St. Jude Donor '13
Kits Contains
Former Vendor
St. Jude Donor '13
Kits Contains
Former Vendor
St. Jude Donor '13
Kits Contains
Former Vendor
St. Jude Donor '13
Kits Contains
Former Vendor
St. Jude Donor '13
Kits Contains
Former Vendor
St. Jude Donor '13
Kits Contains
Former Vendor
St. Jude Donor '13
Kits Contains
Former Vendor
St. Jude Donor '13
Kits Contains
