C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Anyone have 42 lb Ford Green top injectors ?
Old 04-21-2016, 02:18 AM
dllhg
dllhg's Avatar
Default Anyone have 42 lb Ford Green top injectors ?
My local Indy shop told me two of my injectors are a little clogged. I have the Ford Racing Green top injectors that used to come with Maggie 112 kits. Needs EV1 connector. I have had zero luck finding these. I know I could swap out all the injectors for something else but then the tune needs to be adjusted. I have HPT but I have a feeling it wont be super simple to dial in the tune .
Would really prefer to find the same ones if possible. They are holding the 10 PSI at 85% DC. Anything else that would work as a direct replacement without needing to retune ?
here is info on ones I have
Ford SVO Green Top fuel 42 lb Injectors
Ford Part # M-9593-F302
Bosch Part # XL3V-A9A and 280150558
Old 04-21-2016, 11:56 AM
lt1z
lt1z's Avatar
Check your email
Old 04-21-2016, 07:13 PM
liv2race
liv2race's Avatar
i have a set if you need them
Old 04-23-2016, 01:17 PM
gnx7
gnx7's Avatar
Why not send them out to be cleaned/flowed?
Old 04-29-2016, 03:01 PM
dllhg
dllhg's Avatar
Sorry,
I think Im good. Got 3 OEM ones for $60 each. Ford racing gave me the new part numbers for the same injectors. They still make them actually.
To Anyone have 42 lb Ford Green top injectors ?
Quick Reply: Anyone have 42 lb Ford Green top injectors ?
