Supercharger Question
Received 1,193 Likes
St. Jude Donor '15
Good luck with that
If you were to put a small pulley on the centri to make it spin faster at lower rpm and attach an electronic/spring wastgate after the centri volute to bleed off any extra boost you don't need if you're not going for crazy numbers becasue your engine is not forged then you could theoretically get close to instant torque at low rpm and plenty of power up top no??
