C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
D1sc with shot ! Help
Old 05-01-2016, 05:20 PM
Bojwayes
Bojwayes's Avatar
Default D1sc with shot ! Help
So i have ls3 376 with piston and rod 10.2:1 , the mods is cam bolts on with stock heads and manifold and i decied To get 850-870 rwhp , now its 710 rwhp 640 rwtq @11 psi with 6 rib , and icant get more boost and hp because i max my d1sc 61500 impeller rpm , so if i want to switch to f1x i must switch to 8 rib because i did researchs and found that i cant go with 800-870 without slip! Now i decied to spray 100-125 to save money better than switch to 8 rib and f1x , so what advise must i keep in mined before begain ?
Old 05-01-2016, 06:14 PM
Detoxx03
Detoxx03's Avatar
It should be maxed already. What pulley setup are you running? Mine made 780 with a 4.25 before I did the switch to e85 put a 3.85 on it.
If you go F1X I wouldn't even bother with 8 rib and I'd go straight to 10 rib. If that's the plan don't even bother with the nitrous. It may seem cheap initially but it will add up quick.
Old 05-02-2016, 02:27 AM
nareg
nareg's Avatar
D1 with nitrous is a fun setup. For what it's worth I had 8 rib setup with a 3.55 blower pulley with a 8 inch crank pulley and it made 830 on e85. With a 100 shot it made 950.
ZincGT (05-03-2016)
Old 05-02-2016, 03:08 PM
Bojwayes
Bojwayes's Avatar
blower pulley is 3.4 with stock crank pulley 7.5 , and i will not go with f1x head unit because it will need 8-10 rib and they will cost me too much (head unit+10rib= $$ ) but if will go with n2o it will cost me 300-350 dollar for used kit .
Old 05-02-2016, 03:11 PM
Bojwayes
Bojwayes's Avatar
Nice so that iam thinking to go with 125 shot with my 6rib but the question is they will be slip with shot or not ? Now no slipage !
Old 05-02-2016, 03:31 PM
Nitrous Express & Snow Performance
Supporting Vendor
Nitrous Express & Snow Performance's Avatar
Let me know if you need a Nitrous kit, Id be glad to help you out. We even have a forum discount. Message me for prices.
Old 05-02-2016, 04:34 PM
Bojwayes
Bojwayes's Avatar
Thank you i will pm you after geting advises👍
Old 05-02-2016, 05:13 PM
Detoxx03
Detoxx03's Avatar
It's probably slipping now cause with the 4.25 pulley I was seeing 11.3psi with the 6 rib setup. Mine wasn't slipping but if you're running a 3.4 and only making 710 something is off. You should be using 8 rib anyway especially if you don't have a direct drive.
Old 05-02-2016, 09:20 PM
neverstop
neverstop's Avatar
max'd out D1 should be making more than 710whp. something is off imo. I bet your belt is slipping big time right now, especially with smaller crank pulley and 6 rib belt.
Old 05-03-2016, 04:05 PM
Bojwayes
Bojwayes's Avatar
But am looking to the gauge while am test it and there is no slipping, everyting working good !!
Old 05-03-2016, 05:55 PM
nareg
nareg's Avatar
stock crank pulley? When I had a D1 i used a 8 inch crank and 3.55 blower pulley and it made 16psi. Also on a LS3. I would suggest going with a 8 or 10 rib setup and then spray it.
Old 05-06-2016, 08:21 AM
Bojwayes
Bojwayes's Avatar
Actually its depend on CR to get the psi , the stock ls3 piston with stock heads with stock head gasket will give 10.5:1 , my piston dished little to 10.2:1 i think its a reason put me 11-12 psi when my d1 maxed (7.5 +3.4)= 61500 rpm
Old 05-06-2016, 09:58 AM
Slo-Poc
Slo-Poc's Avatar
Do ittttt
Old 05-06-2016, 11:40 PM
neverstop
neverstop's Avatar
anything is possible and maybe the belt isn't slipping but lots and lots of people have made over 700whp on max'd out D1SC so there is a lot left in your current combo, like >100whp with nothing else than working on what is there. I'm all for spraying stuff and I'm sure would be fun to spray it but I'd think the easy thing to do is figure out why you're like 80-110whp lower than other max'd out D1 setups.
Detoxx03 (05-07-2016)
Old 05-07-2016, 01:50 PM
Bojwayes
Bojwayes's Avatar
That what iam asking about it before !
Old 05-10-2016, 07:38 AM
PEETYZ
PEETYZ's Avatar
Running a D1sc on my forged 347 with 8in crank, 4.25 pulley, DP big mouth intake made 15psi and made 715/605 on a stingy Dyno. From what I've seen I can go down to a 3.6 pulley to max it out (need more fuel first). Likely be 20 psi at that point which is a bit scary but ls9 head gaskets and arp studs should keep me in check. Btw I'm running 6 rib as well but have the flip drive with no slip.
I think you should be making a bit more?
https://www.procharger.com/sites/def...ecs-STREET.jpg
http://www.928motorsports.com/servic...tingpulley.php
Old 05-10-2016, 10:34 AM
neverstop
neverstop's Avatar
stock procharger dongle intake could be costing you at least 40whp so that is the first place i'd look.
To D1sc with shot ! Help
Old 05-10-2016, 11:30 AM
nareg
nareg's Avatar
Any updates? Did you spray your car yet?
Old 05-14-2016, 09:14 PM
Bojwayes
Bojwayes's Avatar
Actually i measured the impeller rpm for d1sc and i found the max is 62000 rpm so that i orderd my 3.4 pulley blower with 7.5 stock ls3 crank pulley they will give me 61500 rpm thats mean remaining 500 rpm in safe side for the max rpm , i got 11-12 psi !!! Actually iam shocked because everything work fine no slip ,no leak ,fuel system work good ,meth system work good ! I thought i will see 15-16 psi but i dont know why ! Specailly my cr not too much low like 9.5 or something like that , its 10.2 cr !
Old 05-14-2016, 09:15 PM
Bojwayes
Bojwayes's Avatar
What you mean " dongle intake" ?
Quick Reply: D1sc with shot ! Help
