Stock LS7 Haltech/Aquamist/PrecisionTurbo FenderMount Build
The float is pretty much a positive n negative n sends to signal to the gauge depends how it gets connected it can either read jt right or backwards so wouldn't a float that measures the fuel in your specific fuel sell just hooked up to the gauge n given power make the factory gauge work just having the gauge independently working(kinda like if it was a new wideband gauge been installed)
Received 1,194 Likes
St. Jude Donor '15
Basically you need something to convert a 0-80 ohm sender to 0.7 to 2.5V signal (per tank) that the ECM will be happy with (for both tanks). And the signal has to behave like a stock one would, i.e. passenger tank drains first, etc.
Hopefully it's figured out but dude's will be the first real test. I give it a 50/50 shot working on the first try
That is true, that is how the sender works... However there are 2 of them. One in drivers tank and one in pass tank. When the pass side is empty the gauge shows half full. If at any point the signals get mixed up it throws an error and gauge goes to 0. I am very familiar with this setup unfortunately. I have contemplated going to a cell for quite some time now
St. Jude Donor '15
ECM is expecting the passenger sender to go down first, then driver. I would expect it to freak out if you deviate from that.
I am currently running a sump on both tanks with an external pump. So I am not using the factory transfer function. With both tanks hooked up together they are both the at same level. What I did was modify the sender position an arms so the sender still has full travel but the pass side reads from full to half and the drivers reads half to empty.
running 2 senders in a cell would work but I can tell you from experience, it takes a lot of trial and error to make the floats/senders work correctly.
I was really hoping to have someone chime in like" oh yeh you just need this...". Vengence had to do something with Sinisters tank.. maybe they can chime in.
St. Jude Donor '15
PM'd you.
if the gauge is connected seperately from anything just its own power source to act as a simple gauge when the car turns on and the gauge is then connected to any float the needle will read w.e position the float is in its that simple you just have to bypass all the ******** and make it exactly what it is... A fual gauge for a float nothing else 12v power n ground. If any warning messages come up on the display since the ecu no longer sees the fuel quantity is another problem have someone delete that or live with it but at least ull know how much fuel u have 24/7
St. Jude Donor '15
Or you can make it work like the factory setup.
-Curtis
locosmith (05-11-2016)
#33
Could just max out the passenger tank empty, then use the driver tank sender in the cell.
So the last half of the gauge would read correctly....
Not the perfect solution, but might not show up as an error and would always know when you're going empty..
Would be just like only putting in half of tank everytime you filled up as far as gauge is concerned?
#34
#35
By that's a lot of ifs for some of us.
#36
It'll work I'll throw some power to my car and take a video next week. Have a few interested in it already so once I post the video and confirm it woks as it should. Lead time would only be a few days.
#37
St. Jude Donor '15
Should have it Friday
#39
Haltech PS2000
WB2
CAN
TC4 x2
Literally PNP I loved it. I'll be tieing my meth kit into the system also.
-Curtis
WB2
CAN
TC4 x2
-Curtis
#40
St. Jude Donor '15
Now that's badass
