Stock LS7 Haltech/Aquamist/PrecisionTurbo FenderMount Build
#41
It doesn't work how you're thinking, we all wish it was that simple. My gauge reads 0 and always says low fuel. To get it to work correct the sending unit needs to send the correct readable signal to the ECU. Sure I can get a GM autometer gauge from the Zone and hook that bad boy up and read what's in the tank but I'd rather have the cluster gauge like most. Going to check it in the back really isn't a huge deal for me because how simple it is. Vengeance made it work so hopefully they can give input.
-Curtis
-Curtis
#42
.... each tank has a fuel level sender drivers tank is the 0-50% passenger is 51-100% on the gauge.
#43
Here's how I run my fuel lines, I just cut the back bottom of the trunk area. The setup is pretty good and the pumps aren't screaming at me.
Sorry some of the photos are poor quality due to lighting.
Here's a couple pics of the Aquamist direct port system. I'll be able to explain more on the system when I'm on break but here are some pics for now.
I'll have installation photos up shortly with manifold removal drill and tap for the direct port.
-Curtis
-Curtis
#46
So as far as the Aquamist system goes I have it set up on a dual map with the haltech system. I have the aem electronic boost controller tied into the haltech's Auxiliary inputs and I have the Map switch wire from the meth kit going into a DSI input since it switches faster then an AVI which is better suited for additional sensors or boost control. The Aquamist controller has a built in Relay that will be grounded when it is triggered i.e when the gauge is turned off it turns off the meth kit witch will automatically switch the map on the fly to the No meth/ failsafe map. It can be done in between races during races after etc. so when the map changes it will also change the boost setting since the system is all tied togeather. Once the car is up and running I'll display how it all works on video.
-Curtis
-Curtis
#48
Got everything nice and ready I'm just installing a new starter then testing the meth kit and it should be ready for tuning. I'm still deciding on the D3 catch can or GZ vaccume pump kit
-Curtis
-Curtis
#51
Making my own catch can set up as it's the most cost effective way -10 from each cover. Used some basic home improvement tools and an old welder. I picked up a moroso can and some -10 goodies and braided lines. I'm not too good so please don't bash.
I also grinded down the boss on each side because it was very close to the bung. I was pretty careful with the drilling so that I don't punch a hole through the baffle.
Thanks Dudeman and the guy with the 1.5 mile vette for the tips
-Curtis
-Curtis
#53
Received 1,194 Likes
St. Jude Donor '15
Nice!
#55
Jordan
#57
turbo choice
Why not just go with the Precision 88, unless you are concerned about class restrictions?
Here are some pictures of the new turbo. Physically it is much larger then my S480. It uses a Pro Mod compressor housing, Basically it's a ProMod 88mm Compressor with the tips of the inducer Milled down to 76mm just for class restrictions. It's not just your Ordinary 76mm.
-Curtis
-Curtis
#58
v8 guys love to over turbo their cars.
#60
