RecMech LSX427 F1x standing mile build
#161
I've sweated and bled to get the c5z down to good weight... wondering if ill ever have some convinient place to do a MPH roll race like yourself..
#163
New latches only weigh a few ounces.
#165
A little paint on the exposed portion of the door..
A pile of "extra" parts..
And the finished door. Now I just have to decide what to do with the window controls. I am thinking about moving the driver side controls to the center console.
#167
very nice... you are Dedicated .. I moved my window power to the center.. the drivers window actually is My Nitrous switch panel that says "opener" ...
#169
insane build..... big kajones to go 240mph+
I'm hoping to make a Mojave Mile event in 2017 with my turbo LS9 Rx-7!
My car makes around 1400hp flywheel; however not sure I have the ***** to go 240mph.
I have a rare 2.47 gear to put out back in the 8.8" solid axle mine runs.
This is a good gear ratio calculator to play with......
http://fitbodyshop.net/gear/index.php
#171
#174
Keep it up! Let me know if you need a hand wrenching. I'm up at my folks place in New durham for the holidays for the next two weeks
You just missed out on the fun part! Sent you a PM..
I can confirm the drivetrain will come out on Quickjacks and an ATV lift
#176
Havent really pushed it yet. Running 8"/4.25" under 7200 rpm (put me somewhere close to mfg max gearbox rpm). Plan is to run 4", more rpm and a couple stages on top.
I did end up shifting the 10 rib about .050" off what the laser showed as true to keep it from jumping a rib.. maybe solid motor mounts would help?
#177
yep did you pull down(or up matter of speech) with engine or pulled tube back?
#178
#180
I have to get caught up on updates.. Have been working lots of hours on the car to get ready for a mile and a half event in 2 weeks.
Here is a quick clip with 3" straight pipes in the meantime.
Brandon619 (06-01-2017)
