Let's see your catch cans
I like the MM one for the vaccum pulled on it when part throttle keeps oil clean. Be careful mounting it above the exhaust like that, if leaks oil or something happens could start a fire.
Which is exactly what will go up in flame if fluid gets on it.
I would start by checking to make sure your oil isn't overfull first. That is excessive.
Seen 2 camaros burn to ground from top mount kits that have the headers 1/8" from valve cover. After some miles it cooks the valve cover gaskets, starts leaking oil onto the headers and poof, you have a fireball. People really over estimate how well header wrap works.
The wick comment was meaning I agree with you.
I understood. I've seen a lot of people who just wrap everything on their **** boxes, and results are usually not good.
#34
Supporting Vendor
here are some moue installs -> https://get.google.com/albumarchive/...q2uymTueqZBDEj
__________________
Solutions for the common gearhead #made in USA
mightymousesolutions.com
facebok.com/mightymousesolutions
#mmsolutions
Six time NMCA True Street Champions
Home of the first Twin Turbo C7Z 7.81 @ 176
3470# Stock bottom end and heads Corvette Stock Bottom End Record Holder
#mmsolutions
#35
New mm can
David@MMS (08-16-2016)
#36
I have a E3 and MM can. I originally had an E3 and I still had blowby. Their cans are nice but nowhere near big enough fittings to catch a lot of blowby. Added on the MM for added security and peace of mind. I would say they're about equal. The E3 is pretty thick and seems to hold up great but I have no issues with MM quality either. Don't think I have any pics on my phone however. I may have a video.
#37
https://youtu.be/ESO8vGHPLto
David@MMS (08-10-2016)
#38
Supporting Vendor
cool video, and nice MM can install
#39
Received my new MM can a few days back but haven't had the time/garage space to install yet. Very clean simple design. I'll be mounting mine in the same area as UNREAL's. It has just enough room even with the battery since mine is a narrow body car.
