About to do inline fuel system for e85 (diagram)
#41
Originally Posted by CI GS
I would prefer to use a radiused hose end for the 90* to come off of the tank, even if you use a straight NPT fitting to screw into the tank instead of using the ECS bulkhead (which is a nice piece of kit, albeit too pricey for some). The reason for this is that most 90* NPT elbows are drilled from both sides and have a large step in the corner than restricts flow. See photo below which explains it better than I ever could:
#42
This is what I have: https://goo.gl/images/zB8NXl
#43
Aeroflow makes full flow fittings in various configurations. I guess others would too but I like them.
https://www.aeroflowperformance.com/...gs/af543-10blk
#44
What I was referring in my earlier post was the typical 90* NPT elbow. Every one I've ever seen has a step left in the corner from when the elbow is drilled from each end.
#45
Nice. Do they make an AN to NPT 90* like that too? I've never seen one, but it would be good if they do.
You can see from the pic that the bend is much thicker than the standard ones and that's why they flow more.
