C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
boost sucks, need advice
Old 06-20-2016, 12:42 PM
asteroid
asteroid's Avatar
Default boost sucks, need advice
After install my p1sc1 with slp 25% underdrive harmonic balancer something is going wrong with the boost
procharger pulley size is 3,85
balancer -25%
belt gates 6pk 2213
belt tightened strongly
what is it? is it slippage or boost leak?
Old 06-20-2016, 01:07 PM
realcanuk
realcanuk's Avatar
St. Jude Donor '13
Last thing you want with that blower is an underdrive damper. 25%..... probably slipping like crazy.....
Old 06-20-2016, 01:12 PM
asteroid
asteroid's Avatar
realcanuk **** happens unfornutenately, one man reccomend me to buy this balancer, and I did it. May be he was wrong, but now Im looking how to fix it, without changing damper.... Any advices?
schpenxel
schpenxel's Avatar
Received 1,193 Likes on 1,052 Posts
St. Jude Donor '15
25% under drive pulley with a supercharger...
Of course it's going to slip, at best.
You need to change the balancer, bottom line. It's less surface area = belt slips, and it's spinning slower so the blower is spinning slower. Add those together and this is what you get.
Old 06-20-2016, 01:14 PM
realcanuk
realcanuk's Avatar
St. Jude Donor '13
Log boost and see if its making approx. what it should. If belt is slipping a lot I don't think there is a fix without changing that damper. Maybe a bigger blower pulley but I am not sure really.
Old 06-20-2016, 01:19 PM
asteroid
asteroid's Avatar
Ok, which HB you will recommend for me? LS2 stock + headers+meth+p1sc1
Old 06-20-2016, 01:20 PM
MBB
MBB's Avatar
Agreed..it's the underdrive pulley. Sorry man :/
Old 06-20-2016, 01:21 PM
realcanuk
realcanuk's Avatar
St. Jude Donor '13
I use an ATI 8% overdrive, but there are a few choices. That is just my preference.
Old 06-20-2016, 01:37 PM
asteroid
asteroid's Avatar
can you tell me part number of that 8% overdrive? Thanks
Old 06-20-2016, 01:40 PM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
I'm using Summit C2501. It's a standard diameter but lower cost, ~$200. ATI is a nicer unit and the cost shows it.
Old 06-20-2016, 01:45 PM
asteroid
asteroid's Avatar
Is it it? http://www.ebay.com/itm/Summit-Racin...5XN6Dt&vxp=mtr
Its 8 rib?
Is it good? no problems with it? Slippage?
Old 06-20-2016, 02:01 PM
neverstop
neverstop's Avatar
you'll need a bigger balancer for sure imo, I would just call ECS or A&A, perhaps you can just do the flip/direct drive and that would work? no idea but that one realcanuk recommends looks great
Old 06-20-2016, 02:12 PM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
Its 8 rib?
That is it BUT it is only 6 ribs in Corvette. The other 2 ribs cannot be used on C5/C6
It has been fine for me but I'm running an ECS setup so it's not apples to apples.
Old 06-20-2016, 02:21 PM
chpmnsws6
chpmnsws6's Avatar
Videos are dead.
A 3.85 with that crank pulley is a 4.81 pulley... even if it's not slipping, I'm sure it's weak with that smaller blower.
Old 06-20-2016, 04:01 PM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
Looks like the tensioner bolt is bent too, or is that just the pictures? I've seen that bend more than once. Procharger will tell you how you installed it incorrectly and a bunch of stuff like that. Make sure that isn't bent and the tensioner is working correctly.
Old 06-20-2016, 05:16 PM
asteroid
asteroid's Avatar
Unfortunately I cant call, because Im from another parts of the world, Ukraine, if you know where it is, and my english is not so good to talk for that technical themes...
Old 06-20-2016, 05:18 PM
asteroid
asteroid's Avatar
Thanks for answering, this one is better deal for money saving. I think Ill try this one
To boost sucks, need advice
Old 06-20-2016, 05:22 PM
asteroid
asteroid's Avatar
Tensioner works great, previous bolt was 9cm dia, I made this one new 12cm dia, to be stronger
Old 06-20-2016, 06:38 PM
Unreal
Unreal's Avatar
Still looks bent. Which means it is over tightened which damages the system.
Old 07-07-2016, 06:49 AM
asteroid
asteroid's Avatar
New HB has arrived, next week will be installed and I hope the problem will be solved
Quick Reply: boost sucks, need advice
