Instant crankcase pressure relief.
Hey David you make any of the AN adapters for the Katech valve covers the new ones use a threaded piece not like a factory cap, and its pretty large. I had to take the cap and weld on a -12, but would have liked to have it lower profile for sure.
Supporting Vendor
The 'Holley' Adapters I make are 1-5/16-12 thread. I don't know what the Katech threads are. If you can find that out good, or you can pick one of these up to try and return it if it doesn't work.
http://www.mightymousesolutions.com/...a-02d6fe2ab2d3
I'll call Katech and see what it is. I see on the website its listed as a 2" but doesn't say what the threads are.
Supporting Vendor
any luck?
Supporting Vendor
haha open the box lets find out!!
David@MMS (08-18-2016)
Supporting Vendor
sweet pic, ill add it to the gallery!
Supporting Vendor
Have you test fit under C6Z yet? Does this include the filter? I think I can add the 45deg elbow to have it sit correctly. That would be nice if it was built into the fitting.
Supporting Vendor
you can mount it direct to the valve cover or on the end of an oil fill neck like he did.
here is one for $7 http://www.improvedracing.com/oiling...ductsearchusen
#33
the twin turbo picture above is a c6 i believe.
#34
I just want to get the pressure relief device for the valve cover. Ordering the "Boosted Adapter" will get me the Gen 4 pressure relief device that installs on the oil filler hole (LS3), so is that the red breather/filter looking device for $60.00?
I already ordered the filler tube extension...if it fits.
I ask because the MM pics don't line up with the drop down menu on the site when selecting...
Want to make sure I get the right part...
TIA
TIA
#35
TIA
TIA
Chiselchst (08-20-2016)
#37
Supporting Vendor
Sorry for any confusion with the site; Work in progress.
The current website price for my 'boosted' oil fill adapter being discussed here is $60.
Oil fill adapter pricing start at $30 which covers several other parts in the same category. The 'boosted' adapter is currently only available in black with GM helix mount.
Chiselchst (08-21-2016)
#40
That my opinion anyways.
