Instant crankcase pressure relief.
#81
Supporting Vendor
the valley plate.. some models require using a pcv valve with it (as you have) and some do not. if both of those items are original to your car then that side appears correct.
i presume the business with the two valve covers merging to the ebay can (no breather? on it), end up connecting.. well i don't know. i see you are using a maf so it should be after the maf before the TB but it does not appear. so that is a question
but after that your valley side can does not have ability to release pressure, so basically all blowby routes toward the ebay (non breather) can and eventually/hopefully leaves that can out the other port.. at any rate i can see how this is not enough for your stroker.
I would put my pcv can on that car and get rid of those two, and all that extra hose business, but i am biased
#82
Or contact the manufacturer of your setup. Either buy a MM can and have David support you, or go to the company that you got your can from.
MIGHTYM0USE (10-27-2016)
#83
Supporting Vendor
Thanks for the orders guys, don't forget this features is incorporated to my catch cans!
#84
Supporting Vendor
lets ship some more of these!
here is a cool vid if you have not yet seen.
#86
Supporting Vendor
got some more of these ready to move!
