C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
DP Direct Drive and 8 rib setup
Old 07-09-2016, 08:20 AM
ATLS2
ATLS2's Avatar
Default DP Direct Drive and 8 rib setup
My people, I've decided to upgrade my pulley setup for my ECS1500 Kit and currently have a DP Direct Drive on it. Being that said, which pulleys do I need to upgrade? I'm thinking of IW for pulleys. Side note, should I go 10 rib if I plan to swap to a 2200R next year?
Thanks in advance!
Old 07-09-2016, 09:26 AM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
Blower pulley and crank pulley.
If you go 10 rib you need to order the spacers/etc from ECS, and get other parts, otherwise it is already setup for 8 rib. If you are going to a 2200R I would go right to a 10 rib.
Old 07-09-2016, 10:00 AM
ATLS2
ATLS2's Avatar
Unreal, thank you. You are the man. Do you know if the stock ECS kit on a 10% OD crank pulley would be to much for the Novi 1500? I'm going to uncork it as well.
Old 07-09-2016, 10:05 AM
Unreal
Unreal's Avatar
Goto vortechs site, plug in your pulley sizes, and find out.
Old 07-12-2016, 09:38 AM
MBB
MBB's Avatar
I run the IW 10% OD crank pulley and the ECS 3.25" blower pulley on my 1500. I'm right at the limit. But it also makes 14.5psi with the filter on. So there's that.
To DP Direct Drive and 8 rib setup
Quick Reply: DP Direct Drive and 8 rib setup
