Need help choosing dry sump system, step in!
I have a problem.
I have a wet sump but due to low oil pressure at WOT I really need to upgrade system to dry sump. See the screen shot.
Any recommends of the systems on the market I do not need to change the crankshaft or internal engine parts? Even available?
Looking for simple, reliable system fits to street car, any advise?
Thanks in advance!
Thanks in advance!
Thats under progress. Melling 10296 but pump is not the problem, poor factory oil pan and oil pick up system is the reason I believe.
If your running the short snout crank Aviaid works good. So does the ARE- http://www.drysump.com/3255Spump.htm.
Peterson and Johnson pump are two others that make Dry sump stuff. GL!
http://www.drysump.com/LS%20Tanks.htm
Supporting Vendor
Can you add a Qt and see if it picks up? It should stabilize. Being that your wet sump, you must run it .5-1Liter over full. Literally just experienced this same issue with another TT car.
Now again went to fail safe due to low oil pressure (limiter 3000) when tried WOT pull with new tranny on highway.
Just doubt system using wet sump pump for pressure side if that really solve the problem and is enough at 1500 hp level..
Supporting Vendor
Try running the car at 4-4500 rpm, no load. Light throttle. This will pump the oil out of the pan, faster than it can return ( in the turbo feeds, the drains, scavenge pump, etc etc) and see if pressure just drops.
If thats the case, it may need to be overfilled even more.
But thanks, will test this.
Is it just longitudinal G-force which makes wet sump LS engines hurt or also sideways action? Is this somehow common for just one oil pan design in LS-family?
It seems very alarming (to all drivers..) if you suck the pan dry in just 2 seconds (according to that log screenshot).
I understand if the oil is escaping to the rear of the crankcase but there's not much room there anyways. Could it be that the oil is making foam in certain conditions? That would surely drop the oil pressure momentarily.
EDIT: If the oil pump volume exceeds the need of oil, all excess oil will exit the circulation via pressure limiting valve. This would be worse with higher rpm and big pump. How will the once ejected oil get back to the circulation fast enough?
EDIT2: If it's still stock-type oil pump, it will be a bypass that circulates oil from pressure side to inlet side so that's not an issue (except for oil being heated during that).
I would make the test GSpeed suggested. I'd also make sure you have as thin oil as possible for the temperature. Thick oils are hard to suck through the inlet pipe and screen with high rpm and on average street temperature. I suppose your bearing tolerances are close to stock which makes thick oils more harm than benefit. Just my 2 cents though.. Never had a 4-digit hp car
Looks the problem is G-force, no any issue with oil press at dyno or "mild" accelerations.
Just noticed, oil level was little low after latest dyno session and tranny failure standing five weeks on lift waiting new. Filled little over one quart over factory line. Catch can came out maybe half quart.
Supporting Vendor
When I saw that, that's why I made the comment I did. Throttle has no affect on oilp, except in G force. The oil system could care less what happens when you push the gas.
I don't know but made few third gear test pulls on highway after filled oil, didn't check the logs yet but kept anyway pressure over fail safe limit, what is now 300kpa. Heavy traffic so could not make 4th gear pull unfortunately.
Well back to your question about the head mounting I was going to tell you I still have my A/C and I kept it with my Vacuum pump mounted in same location with out any issues with the A/C and saw multiple Corvettes running the Aviad setup on vette's with A/C Just's a heads up. And for the comment from Juhatt about your bearing clearances being stock. I highly dought that anyone knowing anything about high HP motors would place stock bearing clearances in it. And I totally disagree with the thinnest oil you can find, and think it should just be the best oil for what your motor and setup is doing etc...GL That tranny looks promising!
