Nitrous Outlet Systems on Sale!
Former Vendor
We currently have a few systems in the shop that are boxed up and ready to be shipped. These systems have 4AN feed lines (except Stinger and Hornet plates), and are limited to 200HP because of the feed line size. Because these are already pre-packaged, we can't make any upgrades to them but we are selling them for 10% off. If you have any questions or need to place an order give me a call at 254-848-4300 Ext. 104- Andy
00-10040-10 Universal EFI single nozzle system (10lb)
00-10116-10 102MM Dual stage plate system (10lb)
00-10200-10 EFI dry Single nozzle system (10lb)
00-10123-10 92MM Fast Intake 05-09 c6 corvette (10lb)
00-10124-10 90MM 05-13 Z06 plate system (10lb)
00-10601-10 4150 Stinger Plate system (10lb)
00-10601-15 4150 Stinger Plate System (15lb)
00-10636-10 4500 Hornet Plate system with boomerang bracket (10lb)
An open letter to N2O Outlet:
While I have yet to use your product, I did buy the complete package all the way from heated bottle to fuel line and wide-open-throttle to all the way up in the engine bay where the relays and solenoids run wild.
Bottom Line: Your instructions are not only inaccurate, but also contradictory and potentially lethal to the end user. I not only have buyer’s remorse beyond the Milky Way, but also have disappointment the size of the sun. Below are some of the examples I will share with anyone daring enough to consider purchasing your product as it currently stands. I am not inclined to site specifics as I am not a paid member of your team. THIS IS YOUR RESPONSIBILITY. THIS IS YOUR RESPONSIBILITY.
• Contradictions in your instructions are common. Not only within the same document, but also in corresponding, related documents.
• Why do you not put a compendium together (A-Z) of instructions? Wouldn’t it be easier for us shade tree mechanics to know we have all the required instructions instead of only guessing we do once on your website? AND MAKE SURE THEY TIE WITH EACH OTHER. Right now I have 5 relays under my hood. Is that really necessary?
• The color code standard (I use this phrase advisedly) you use for your relays can be described in one word: insane. If you take the time to open a kit and look at the instructions, this will become an embarrassing revelation to you immediately.
• The instructions do not identify everything in your pictures for inventory purposes. Maybe others know what every piece in the N2O Outlet kit is, but I sure don’t. I suspect I am not the only one either.
• Why not use YouTube for an instructional video?
• I called you all for an extra part and I mentioned I was having difficulty with the instructions. The N2O representative stated feel free to call you guys. I asked if you had weekend hours…silence. Newsflash: not all of us in this forum are doing this on the weekday. Weekends are the sweet spot of when these installations are getting done. And if you can’t get the product I called to order out in two days, then don’t charge me for two-day service for your logistical problems. A bad business model.
• A summary of the concept of the install would be very helpful for those of us not installing these kits on a regular basis. There are a lot of modular parts and it would help to understand how the puzzle fits together.
• I went to a nationwide vendor for nitrous bottle fill and they noticed a potentially lethal error in your labeling.
• The only time I knew I needed a “Power” Relay was reading your instructions. No one ever mentioned this beforehand. Great! Another weekend blown (pun intended).
Yours Truly,
An Unsatisfied Customer.
Yours Truly,
