What size belt for this combo?
I have an A&A V2 Ti trim blower with a trick flow HB (see attached)....going to pulley down to a 3.6 and want to know which belt to purchase.
I only made 7psi with that combo. I trashed a belt due to an alignment issue. Then I just went down to a 3.25 pulley. (11PSI now)
I have a 3 new, Never used betls I had as spairs that are to long now.
1-K060915 $30 shipped.
2-K060910HD (Heavy duty green) $35 each, shipped. (I have 2 of these)
I have an A&A 3.4 pulley for $80 shipped
Let me know if you end up needing any.
I have same exhaust, Ported heads & blower cam. I don't know what the power is. I go back next week for the final tune. Lost the belt on the dyno and just wend smaller on the pulley and fixed a few small issues.
I just had the same set up and I used a K060915. Fit was tight.
I used the K060915 with the 3.6
I'm using the K060905 with the 2.75
I was going to use the K060910 with the 3.4.
No rush. I don't even have them listed for sale.
I was buying the belts in sets of 2 incase I needed a spair. Didn't want to get stuck on the road. I never even mounted the 3.4 / 910 comb. Just went down to the 2.75<br/>I got the pulley used but it is a 9 out of 10 on condition.
Can you pm me your best price for the 3.4 / 910 shipped to 39564?
Platinum Supporting Vendor
If you have the older 2pc bracket before the new Billet Tensioner came out this year then use a Gates K060905 or K060905HD.
If it's a 7.5 balancer it will still be under spun to about 48,750. Max blower recommended blower speed is 55,000 if om not mistaken. They A&A guys can chime in and clarify This if I'm wrong.
Vortech impeller calculator:
http://www.vortechsuperchargers.com/page.php?id=33511
V3 Si and V3 Ti max impeller speed is 52,000
I only roll the dice and over spin V1, V2, or V7 headunits myself, not V3s.
Is the V3 a S-trim and the V2 a T-Trim head unit? Or a Novi 1500 = V2
I'm not sure why they are not more specific.
