Lets see your wideband/airflow gauges
Originally Posted by Dude_man
Does yours have a black box that goes between the sensor and gauge? The uego box?
Wasn't sure if you were using their wideband or not. I may know who makes them
Ther aeroforce is a nice little gauge. Had I known about the dash logic at the time I would have bought that but it is nice being able to read and reset codes with the gauge. Since I have a blower I am really not concerned with boost but I do have the gauge set up to read timing retard and IATs.
I run the Innovate MTX-L wideband and haven't had an issue with it yet. I wanted a dedicated wideband right in my face while I was driving to make it easier to see.
Nicest feature of the aeroforce is to be able to set alerts... and even combine things. For example alert if boost is over 3 lbs AND afr is over 12.... or any combination of things.
I have a dashlogic and aeroforce. Dashlogic all day over aeroforce. I can't stand the aeroforce. If I could decide on a different gauge to plug the hole, I would gladly ditch it and run something else.
Mine works perfectly and it comes in so handy to check things when I don't feel like hooking up HPT.
Had 2 aeroforce FP sensors go out, which isn't directly related to the gauge, but still annoying. Can't read it with sunglasses on, which is 99% of the time. Interface is clunky, and slow. Its not bad, I just wouldn't get another, and think there are better options out now. The display is way out of date.
#33
Just FYI, I think you can do that with Dashlogic also. It can make a chime, display something in the hud and/or display something on the DIC.
#34
#36
Agreed.
It is also missing a few PIDs that I would like. Doesn't read everything.
#37
I don't have any external sensors displaying in the Aeroforce so maybe that's why I like it as much as I do. Being able to read and clear codes is worth it to me. I would like to be able to read ethanol content on it which I think they did a firmware update and it is now supported. I could be wrong though.
If I had a HUD I would have bought the dash logic already. I don't love the idea of having to look down at the cluster to see the info.
#38
Received 1,194 Likes
St. Jude Donor '15
Add HUD
#40
St. Jude Donor '15
Yes.
