D3PE PROSPEED C6 Supercharger Heat Exchanger System!
Former Vendor
Introducing the D3 Performance Engineering PROSPEED C6 Supercharger Heat Exchanger System!
Based on our highly popular D3PE ZR1 Heat Exchanger System, we are now offering the components for the D3PE PROSPEED C6 Supercharger Heat Exchanger System to be available as a complete replacement upgrade for the aftermarket HX systems commonly found on today’s Screw and Roots style Supercharger Systems.
This system comes standard with our reprogrammed Stewart EMP WP29 water pump, which when tied into our 1.00" lines allows for a flow rate of over 12 gallons/min, compared to a stock ZR1 HX Pump rate of 6.3 gallons/min!
Also standard with the system is our 36mm thick, high fin density front mounted heat exchanger, as well as dual coolant recovery tanks which reduce pump cavitation while increasing system capacity to over 3 gallons!
Complete Kit Contains:
- Front mount high fin density heat exchanger
- 1.00" hardlines and silicone hoses
- Upper recovery tank
- Lower recovery tank
- Quick fill spout
- Reprogrammed Stewert EMP WP29 pump
- Power steering cooler brackets/duct hole covers
- Horn relocation bracket
- Pump mounting bracket
- All needed hardware/Instructions
Now available on our webstore for purchase at the link below!
http://www.d3peparts.com/product-p/d3pe-c6hxkit.htm
- Quick fill spout
427ZM (07-20-2016)
Former Vendor
Nothing has changed from ZR1 Heat Exchanger System and the cost is still the same.
