Those who are pulling (crankcase pressure) from both valve covers
Originally Posted by realcanuk
My Holleys cleared the stock alternator and the billet tech.
Supporting Vendor
here is a quick and easy way to get big ventilation from a Holley LS cover.
unscrew oil cap, screw in place my -AN oil fill adapter
i have these in 8/10/12 an $30ea
single fitting i rate at 800/1000/1200hp respectively when hooked to my catch cans.
http://www.mightymousesolutions.com/...a-02d6fe2ab2d3
__________________
Solutions for the common gearhead #made in USA
facebok.com/mightymousesolutions
#mmsolutions
Six time NMCA True Street Champions
Home of the first Twin Turbo C7Z 7.81 @ 176
3470# Stock bottom end and heads Corvette Stock Bottom End Record Holder
#mmsolutions
Supporting Vendor
a single 10 i rate at 1000hp so you would be fine with that since your around there at 800whp
I just put on a set of the tall Holley covers in red. They came with a bracket to relocate the first coil on the driver's side. They clear the alternator. My car is a 2007 LS2.
Good to hear. I'm swapping my setup to a all new setup. Ordered it today.
The following 2 users liked this post by Unreal:
David@MMS (07-27-2016),
MIGHTYM0USE (07-27-2016)
No details until its done.
Supporting Vendor
#33
Tasty MM goodness.
David@MMS (07-30-2016)
#34
Received 1,193 Likes
St. Jude Donor '15
Yours is almost as dirty as mine. I like it.
Catch can looks nice too
