8 Rib Pulley Install - Tricks?
I could use a quick response. I am preparing the car for a SC install and have a PowerBond 10% OD HB that has been on back order for 2 months. I was planning on going 8 rib then saw a thread that made it sound like putting on the pulleys is a significant job. I am considering canceling the PB and ordering an Innovators West kit since they have them in stock. However, it looks like they don't include the spacers, bolts, etc. compared to the A&A 8 rib conversion kit. I don't see details from ECS on 8 rib.
What "special" tool is used to put on the Innovators West HB? They don't show a picture and I assume it is the method using a long piece of threads.
Can the other pulleys be swapped out w/o special pullers?
The thread I saw was not for a 07 Corvette but they had to grind, use washers, etc to get proper alignment. Is any of that involved?
Received 1,194 Likes
St. Jude Donor '15
Balancer just goes on with normal balancer install tool.
The other pullies are where you get into having to move them in or out to make sure everything is aligned.
Ecs comes standard with spacers and pulleys for 8 rib. If you have an a&a kit you need to call Josh and order the spacers, etc. I would order the parts from the vendor of your kit.
I thought the pb didn't work for 8 rib?
