Overvolt with ECS 1500
Going out on a limb here - I am having issues where when the car is under load, my alternator is overvolting.
I ran a few tests and without the blower under load, the car runs perfect 13.5-14~ volts. If I put the load of the blower on, it goes to 15.5~ and slowly increases. The max I've seen is 16.5.
I was thinking voltage regulator but why would it only be affected by the load of the blower and not when I had it N/A during my test?
Also - will 16.5~ volts hurt anything if briefly spiked to for a few seconds?
I tried another alt but it was a bad reman I think. Started the car and it went straight to 18V at idle.. I know it was a true reading because all my gauges started going berserk. I shut it down immediately. Got the old alt back and it's charging fine (except under the blower load).
