Normal Oil and Coolant temp
2008 Z51 ECS1500 running 11PSI with Meth injection.
I'm running the following Temp with outside air at 92 deg doing 75 in 6th gear RPM about 2k
Coolant 210
Oil 230
Question is this normal? At what temp should I be concerned? Is oil or coolant the more critical one?
Coolant 210
Oil 230
Looks good to me on a stock thermostat. No worries. I start to ask questions when water gets above 220 in normal conditions and get worried above 245 ever. Oil temps I get worried above 290 and throw yellow flags above 260.
Received 1,194 Likes
St. Jude Donor '15
That's nearly exactly what I see on mine too
Thinking about adding an engine oil cooler to get the oil temps down a little bit, but that temp isn't hurting anything.
I generally see coolant at 196 on the freeway. A&A kit with DeWitts rad.
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,085 Likes
Stock fans do not turn on until 220's and preferably you want the oil temps to be at least 220 so any condensation evaporates.
You want oil temp in the 220-240 range. Thats typically where it works best, and hot enough to burn off condensation.
<235 on water temp is fine. Thats what factory is setup for.
It always makes me nervous seeing the oil temp creep up to the 230F+ range. Water temp rarely goes above 215F with the AC blowing cold. Even when beating on it. I guess these temps are fine.
I have the OEM oil cooler and lines, but have been unable to figure out how to make it fit with the turbos.
St. Jude Donor '15
~245ish, and 290+ but that depends on oil.
Car will give you a warning.
C7Zs typically hit 230-240 with ease during a lapping session.
St. Jude Donor '15
Running Motul here
bobistheoilguy has more about oil then you'll ever want to know
My GS EOC ran ~160-185*F with the stock air/oil cooler. Now with the DeWitts EOC (and the air/oil cooler removed), it runs a more consistent ~165*F, and warms up MUCH faster than with the stock GS cooler...very happy with that. Warm up time previously was way long.
I rented a '12 base, and beat on it hard and EOC was never much over ~250*F in mid 70's ambient temps, FWIW.
IMV, oil doesn't need to reach 212*F to "boil condensation/moisture". The aeration, agitation (and localized areas that reach much higher temps) will vaporize all/any moisture/H2O. The Red Line tech - local to me - also has the same view. His opinion was that a min oil temp of 160*F is desired, without the *need* to reach boiling point of water (212*F) for adequate moisture vaporization and removal.
My new DeWitts ECT's run 170-195*F w/ a 160F stat, with air movement at 40 MPH <. Closer to 170*F at 70+ hi-way only.
My opinion, worth what you paid for it...
ECS 1500 kit with built motor and mine gets hot quick. 220-235*F coolant at slow cruise 40MPH in 4th gear with A/C on and 235* oil temp. I don't feel comfortable running the car that hot given the driving parameters. Does the DeWitts EOC make that much of a difference or should i be focusing my attention elsewhere? I don't think a 160 stat will help me because I am already past the point of where the stat is fully open(i think).
St. Jude Donor '15
Thermostat isn't the issue IMO
Stock fan/radiator setup?
yes and all OEM coolers are in place. I read some threads about adding side shields to force air through the radiator. Some people are cutting up the front bumper also which is something I don't think I want to do at this point. Given all the heat, the A/C performance at a stop light is terrible also.
I have a theory that the holes cut in the top shield for charge piping and intake tube are also allowing lots of air to bypass the radiator.
My car has an aftermarket carbon hood also but the cowl area is not cut out. I wonder if adding some holes will help as well.
