Need help
6th Gear
Need help
Came home from work yesterday and jumped in my Z for a quick run. First the check engine light came on so I pulled over, shut her down for a few minutes, and jumped back on the road. Then I noticed my boost gage was still at 0 and my blow off valve wasn't dumping, so I limped back home.
Was the check engine light on because she was running rich because of the pressure from the supercharger and why wasn't she dumping like normal????
ZO Sik (08-13-2016)
6th Gear
Received 1,193 Likes
St. Jude Donor '15
Check codes first.
I wonder if a hose for the bypass valve came off? That'd cause a nice vacuum leak and leave the valve closed all the time.
