12.8 a/f ratio on spray
08-20-2016, 08:57 AM
I know this is not a ideal a/f ratio but how would I change this to get atleast 11.5 or so? It runs 14.7 n/a also
08-20-2016, 10:09 AM
wow.what in the world. you need hpts
08-20-2016, 10:10 AM
my car on spray made grate power around 12.5 on spray it would make alot more even leaner
08-20-2016, 11:56 AM
Assuming you have a wet kit and good fuel pressure, keep putting a bigger fuel pill in or drill out to taste. How big a shot?
08-20-2016, 12:07 PM
The problem is the car is lean on motor at wot
08-20-2016, 12:08 PM
12.8 on a shot isn't really that bad. Is it ideal no not really
08-20-2016, 08:33 PM
It was checked when a 150 wet shot went through the car but I was going to drop back to 100 shot
08-20-2016, 08:35 PM
Sounds like you have a vacuum leak .any air that inters the motor after the maf will make it run leaner then when it was tuned or even from oem
08-21-2016, 07:03 AM
I wouldn't run it 12.8 on spray low 12s would be ideal for safety reasons but of course each car/setup/tuner is different.
BUT 14.7 N/A !?!?!?!
08-21-2016, 09:59 AM
Quote:
Originally Posted by
venomws7
Lean is mean right?
08-21-2016, 03:15 PM
St. Jude Donor '15
That lean ain't mean, it's stupid
08-21-2016, 07:56 PM
I think your solution here is get a good tuner
08-21-2016, 09:06 PM
Was the a/f like this before? Or did this just happen
08-22-2016, 09:39 PM
.. along for the ride . im running a stand alone with maxnos fuel and a/f is 11.5-12.0 its a dd and no way do i wanna take a chance of detonation.
08-22-2016, 10:11 PM
A good a/f on the dyno is fine for a base tune on spray .12.0s 12.5s but nitrous should be tuned at the track after the dyno, plugs must be broke down and read .car starts in the burn out box an shut off at the end with no run time on them .
