My Custom Twin Turbo build....Turboporn warning!
I know! I figured the community needed another because it was getting slim with build threads these days. Haha
That's pretty amazing. I would like to see the graph and or log.
My 62mm with a small turbine made full boost in that same area.
I'm only going to make as much power as I can use. I don't think it's anywhere close to 2000 even.
I'll turn it up on the Dyno just to see the diminishing return point for boost though.
We just finished a 427 LSX with twin 7675s, in a standard .96 t4, and its lit by 3800/4000. Minimal spool. I busted nick yoskins ***** a few years ago, because on paper, it should be laggy. However, it's not.
@16psi, it made 1220/1100, and carries to 7k.
Build looks good! Can't wait to see it completed!
Supporting Vendor
very cool, good luck with it!
Hi Everyone,
Just a quick update. I finally got all the can bus communications in the car completed. Big thanks to my friend over and Obsidian Motorsport!! He spend over 8 hours programming all the can bus and display data to work. It wasn't an easy task getting AEMnet (29bit can bus) and MSCan(11 bit can bus) to talk to each other and work properly!
Now my ecu and CAN system can transmit/receive all the individual cylinder O2 and EGT data. The Motec dash is going to look sick once it's mounted in place.
First startup with the can bus working and Motec dash readout:
After working with the tune and getting closed loop feedback setup for the individual cylinder control. This is a 840rpm idle on decent size turbo cam. I think I can get the car to idle as low as 750rpm smoothly. It's amazing how smooth the car is with this much control!
I'll update again in a week(ish) when I put the car on the dyno and breakin the engine.
Hi Everyone,
A brief update on the progress of the car.
The 6870 Turbos are doing work. So far I have been able to make 1312whp at only 20lbs of boost. At this point the car is picking up almost 50hp per 1psi of boost!
I will post up some dyno graphs tomorrow and some more videos in a week or two but so far it is exactly what I hoped it would be.
Here is a short in car video at 15lbs of boost. Don't mind the date stamp in the video. haha. I was too lazy to fix the date/time on the camera before getting started.
I will leave the car at this setting until I get some more seat time. Sometime in the Fall I will turn it up to 1500-1700hp range and give it hell.
-Josh
-Josh
Received 1,194 Likes
St. Jude Donor '15
Needs more oxygen sensors
St. Jude Donor '15
Is the rear radiator still working well?
#33
St. Jude Donor '15
That is awesome. I guess it's getting plenty of cool air back there vs. being stuffed in with everything else up front.
#35
sweet mother of god.
love the rear mount radiator. I envy how the 911s hook up on the street and would be great to move more weight back there and also unclutter the front.
#39
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
Cool build!
What headers?
What are you using for boost control? I don't see any waste gates.
What headers?
