World Big LS Engine 507ci With MoZeZ Heads N/A for My ZO6!!!
#41
KaNDriZO6
First Start Engine Fast work need to repair wire and hose fuel system just we need to listen sound engine and check oil pressure
http://d.top4top.net/m_2633t8s0.mp4
http://e.top4top.net/m_2633yb71.mp4
#51
KaNDriZO6
lool
i tell for all friends about dust if i got
900rwhp I will work a big party, and cleaning and washing polishing
850rwhp clean only
800rwhp nothing keep dust lol
750rwhp i will remove engine!!!
#54
KaNDriZO6
i have problem in the tune
the driver side pistons the a/f is good 12.5 another side 15.5 have problem to lean
i think need to change the fuel system style but why i got problem i have world big pump fuel weldon for 2400hp 10an the fuel line 12an
when do run the headers fuse side come orange
i have this design
should need to change this design ?
i have this design
#55
Received 1,193 Likes
St. Jude Donor '15
Second design is def. better
What injectors are you running and have they been checked out? Maybe swapped pass/driver sides to make sure problem doesn't follow?
#56
First design started being a problem for inconsistent fueling when I was around 1000-1200 rwhp so from then on I do it like you second design, And I'm only talking about your supply and return from the fuel rails. The pumps I've done both ways with no issues. I agree with schpenxl to trouble shoot and see if it follows the Injectors. Another possibility is valve adjustment, A TON of ppl struggle with it and it can and will cause issues with the AFR. And if all that your 100% on then I'd be looking at wiring etc... GL!
#57
KaNDriZO6
KaNDriZO6
3 run i got AFR presser side 12.5 and the retain side 16 i change just place after i got more 80rwhp and good AFR but not 100%
last run driver side pistons 12.5 and fuse side 13.8 i got 80rwhp
now want to change to second design
need 2 Y 10an just and do you think change fuel rail to go 10an or 8an the mast make it 12an i can swimming in side lol
#59
the wiring is 100% i think need to change the fuel rail The Mozez intake come with big port fuel rail 12an to much big
C6ZO6-2006 (10-31-2016)
#60
