Pulleying down....3.6 or 3.4....?
#62
Received 2,275 Likes
C4 of Year Winner (performance mods) 2019
V3 Si maxes out with the 3.4 pulley and stock balancer at 6500-6600rpm. So no you shouldn't run the 10% od balancer with a 3.4 pulley, unless you plan on shifting around 6000rpm.
WESTFREESTYLE (11-30-2016)
#63
Actually the Si max out at around 55k if not lower. I was maxing my Ti with the 3.25 pulley and a TF balancer which is 7.54" when turning to 6,800 rpms. It was over 60k.
I went up to a 3.6 pulley, removed the restrictor and the IATs went down and boost peaked at 12 while reaching about 53k on the blower at 6,800 rpms.
#64
V3 Si specs
Max rpm of the blower is 52,000rpm
Impellar speed calculator
7.5" crank pulley at 6500rpm engine speed and 3.4" pulley gives 51,617rpm impellar speed.
#65
Ti is very different from Si
V3 Si specs
V3 Si specs
Btw, the stock balancer in our cars is not 7.5 more like 7.25. Several shops have confirmed this.
#66
WESTFREESTYLE is a manual (dry sump) GS like mine, which uses the LS7 balancer. According to ATI, stock LS7/LS3 dry sump with AC is 7.65".
#67
I didn't know the balancer of those dry sump engines was different. I stand corrected then. So not all C6s have the same size balancer. Wonder what is the size on the LS9. Thank you for sharing that info.
#68
I was unaware of the balancer size diff myself, learned something new! Thanks for the info Evan70!
