2005 LS2 and E85
2005 LS2 and E85
I am wondering what the fuel system requirements for an LS2 to hit around 650 RWHP.
Right now I am at 559. I have 60 lb injectors, Racetronix fuel pump hotwire and also a KB Boost A Pump.
I asked my tuner if I added 80/85 lb injectors, could I use E85 and he said no. Then I asked if I added 100 lb injectors and a Z06 fuel pump and he still says not enough fuel system
Received 1,194 Likes
St. Jude Donor '15
What fuel system would you want if you were making 850rwhp on gas? It's pretty much the same thing.
Simplest solution is some ID1000's and fuel system wise I think an ECS stage 1 would get you there. And you'll want to add flex fuel sensor of course.
I'm going to do a write up sooner or later that lists out all the part numbers needed to do a full return system on one of these for about as cheap as it can be done while still using PTFE hose, etc.
DOUG @ ECS (10-28-2016)
Contact dsx tuning for your flex fuel parts.
When I was in your spot, I went from basically your setup to a big single pump (Eliminator), big lines, dsx pump controller, and ID1000's.
I changed everything to run E85
I installed Racetronix dual 340lph pumps(2nd pump on 7psi hobbs switch) -8an Teflon feed, -6an Teflon return, racetronix E85 regulator set at 60psi, larger fuel rails, dedicated motorsports flex fuel sensor kit, and 127lb(1300cc) injectors...
A&A t-trim at 9 psi and flex fuel sensor reading 57% ethanol(some 91 still in tank) netted 722rwhp on the dyno...
Now im at 11psi and should have 70-75% ethanol(winter grade E85) which should be around 750rwhp...
My buddy has the fore triple pump kit and likes it.
ECS kit that doesn't require dropping the tanks looks like a much easier way to go if your willing to gamble with factory pump lasting on ethanol...
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,087 Likes
We have also dropped the pricing on our fuel systems fairly substantially, along with also sending all the fuel lines pre made ready to install.
The factory fuel pump is E85 compatible since they are often used in flex fuel cars, and our fuel system is also E85 compatible.
The stg 1 system will fit your needs just fine, but if you up the power later then building on our system is simply add on's, no wasted money unless you are really stepping it up and need a larger pump.
Here is a link to our site, thanks for your interest!
http://www.eastcoastsupercharging.co...ategory_id=302
__________________
C5/C6 and C7 Supercharging Specialist
ECS Supercharger Kits / Mantic Clutches
www.EastCoastSupercharging.com
Facebook Page
ECS YouTube Channel
Facebook Page
ECS YouTube Channel
