Setting up to Datalog
HPT Pro came yesterday. I am setting up today to get my WB wired/programmed in then I will start some datalogs on my stock tune.
Next will come the A&A install. I am getting more confident with tune parameters and have been spending numerous hrs on HPT, also some informative youtubes out there.
I am please with the pace in which I am accumulating tune knowledge. Probably a snails pace for most, but I learn best by really over doing it by most others' standards. I want to get comfortable with the datalog stream from actual drives I do, and the PIDs I want to track for the FI install.
Question about MAPS - I saw some threads discussing the ZR1 MAP. Will my stock MAP work with the AA install? LS3 2009 E38 stock setup, and the AA FI install will be run at a modest 6/8 PSI. What do I need to read boost on dashlogic?
Stock map won't read boost. If you are not doing a SD tune, then it isn't required as fuel is set of the maf sensor. If you want to read boost you will need to swap the map sensor to one that reads boost. If you want to run Speed Density you need one that reads boost.
Received 1,193 Likes
St. Jude Donor '15
You'll want a ZR1 map. Factory map will only read to ~1psi or so. Dash logic won't read boost without one.
You can get by with a MAF only tune with the factory MAP sensor, but it's not really ideal. Injector flow rate is calculated based on fuel pressure (58psi) + vacuum (or - boost) so I prefer to have a boost capable MAP sensor. Also, apply the OS Patches in HPT for "manifold vacuum boost".
(lol)
(lol)
OK thanks guys, as always.
ZR1 map it is then.
ZR1 map it is then.
