Flex Fuel Conversion
#41
Makes sense. I have some 85# injectors laying around if you want a good deal. They are the injectors that A&A includes in their LS7 Vortech V3Si Trim supercharger kits. I believe they are FIC 850s. I'll check if you're interested just PM me.
#42
I called on Monday and the deal is only if you buy with over priced injectors. They offered zero discount on their sensor??
How do you like the Fore system? How was the install? Any pics? I'm on the fence with ordering that set up or just doing the A@A external pump with the return line. I like the idea of not messing with the stock pump and tank internals.
If you don't mind doing things multiple times and working out the bugs, than you can save some cash by piecing things together, although I'm not sure its cheaper in the long run.
#43
If you like no hassles, easy install, and things that are proven to work, the A&A fuel system and the Dedicated flex fuel setup are the way to go.
#44
Originally Posted by KM177122
But it really depends on your power goals.
