#1 cylinder plug concerns
Just pulled plugs and cylinder 1 plug is much darker (carbon) and wet (oil)....thoughts? Going to do a compression/ leak down test and see.....also going to boroscope it to see what's up....hopefully
Compression test results...
* do all these plugs look dark?* all cylinders held pressure reading great....too big of a variance?
Put new plugs in,reinstalled plug wires and coil packs....now having a constant misfire.....car was running smoothly/great before we pulled plugs and was unaware of any issues til we looked at plugs. Now car is running like crap! Re-inspected all connections.....where to now??
Put new plugs in,reinstalled plug wires and coil packs....now having a constant misfire.....car was running smoothly/great before we pulled plugs and was unaware of any issues til we looked at plugs. Now car is running like crap! Re-inspected all connections....where to now??
Going to buy a cheap set of plug wires tomorrow (when I get off duty) to just troubleshoot the issue.....before buying a really good set if that is the problem
My vote is that one of the wires failed after they were pulled the first time. I changed mine over to the firecores 5.0 due to the lack of consistency when removing and reinstalling the oem ones.
Btw, it looks like you have a failed valve seal. Not a big deal since you're planning to replace valve springs but just make sure you order the correct seals that fit with the aftermarket springs.
Yes, you buy an adapter to screw into the spark plug holes and hook shop air hose to it to pressurize the cylinder you're working on and hold the valves up when you remove the locks and springs. then a good pair of 90° needle nose pliers grab the old seal move it side to side while pulling up and it will come off. use a socket to tap the new ones on. it's time consuming but a pretty easy task. also make sure to soak the new seals in oil for 24 hours. there are several youtube videos of how to do it.
Would painting the coil packs cause a grounding issue, therefore causing a misfire?
**found problem! Was a loose connection on #3 cylinder injector**
*update* pulled plugs again after 200+/- miles and #1 cylinder was darker/carboned up more than the rest.....anyway to determine bad valve seals vs. Bad oil rings? What damages oil rings....detonation? I'm running 7-8lbs with meth for safety and get ZERO knock on dashlogic display....?
