C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
other parts i should need with twin turbo set up?
Old 12-07-2016, 03:31 PM
joewarner
joewarner's Avatar
Originally Posted by CK@UPPCOS
Then really all you need too look into is going to be a clutch....and maybe a set of stickier tires!
Already have a set of stickier tires on their way.
do you think i can hit 700whp without meth? keeping the cam i have now?
Old 12-07-2016, 08:49 PM
KM177122
KM177122's Avatar
It all depends on how aggressive you go with the timing on your tune. Meth and higher octane race fuels allow you to run more timing since they basically prevent knock. Hence insurance. C5R timing chain is also a smart move and is affordable. These are all supporting mods so that your setup lasts as long as possible.
Old 12-07-2016, 08:51 PM
KM177122
KM177122's Avatar
What size turbos did you get with the kit? Cubic inch of your motor? Manual or auto trans? Most twin turbo kits can easily hit 700whp.
Old 12-08-2016, 09:08 PM
joewarner
joewarner's Avatar
427 stock ls7 block, 6182's. bought for the future when by the summer time and and im built motor.
Old 12-08-2016, 09:34 PM
KM177122
KM177122's Avatar
You can easily hit 700whp with those turbos and on a 427. However, like you already mentioned, blowing the motor up. LOL. Unless you are running her on meth, E85 or another form of higher octane fuel, the LS7 doesn't handle boost well. Believe me, I know from experience. Preventing knock by running a better fuel and staying very conservative on the tune/timing is pretty much the only saving grace for a boosted LS7. With that said, I have seen a number of 700-740whp LS7's hold up for a long time but they run meth or E85 etc...Luckily you are running bigger turbos so you can make more power with less PSI hence, a more conservative tune and still hit good power numbers.
Old 12-09-2016, 01:06 AM
joewarner
joewarner's Avatar
any suggestion on meth kits?
Old 12-09-2016, 01:55 PM
0CK@UPPCOS
Former Vendor
CK@UPPCOS's Avatar
If you're going meth I'd go with Alky Control. Julio over there is a great guy and their systems are on point.
-CK
Old 12-10-2016, 06:18 AM
KM177122
KM177122's Avatar
Alky Control is what I was going to recommend as well.
Old 12-12-2016, 11:14 PM
MOTOWN Z
MOTOWN Z's Avatar
Alky control is the only way to go when it comes to Meth kits.
Quick Reply: other parts i should need with twin turbo set up?
