Nitrous Standalone Fuel Options?
What do you recommend or what are you using?
Anyone using VP NO2, Ignite 114, MS109, C16?
What are cons or pros of each?
C16 or E85 usually
I'm wondering about that VP NO2 mostly. It's over 120 octane.
Wouldn't you think a higher octane would be better? I think its around $85 for 5 gallons.
I know several guys running the oxygenated MS109. C16 is leaded. I'm curious if that could have an ill effect on O2 sensors.
Turbo2L (12-03-2016)
Is there a happy medium with these fuels and nitrous or is the higher octane just more protection from detonation with no real power gains?
It really depends on what kind of power you are making. I had to move to a standalone for anything over a 125 shot. I was making about 550rwhp during that time. I moved to a standalone and have ran a 250 shot without issue.
It's not so much how much power you are making to begin with, its all about ignition timing. You get to a point where regular gasoline or E85 on a certain shot size (different for every build) requires so much timing pulled from the tune that engine doesn't make anymore power with additional nitrous.
Having a standalone tank/pump to spray a race fuel will allow you to add more timing and make more power without detonation. That is the reason I started this thread. To see if people have tried these fuels and found that one worked better than the other.
LedfootLarry (12-23-2016)
I get what you are saying now. I was thinking the pump was a given. I didn't really consider someone buying a standalone system instead of just upgrading the pump.
You don't want to pull from the rail when you have a healthy N/A motor. You will introduce a lean spike the pumps will have to overcome when the fuel solenoid opens. Its is ok for a 370whp LS2 with a 125 shot not so much on a 570whp 416 on a 150 shot. The standalone is worth it for fine tuning the nitrous independent of the N/A tune as well.
Former Vendor
Using a dedicated standalone fuel system will help you prolong the motor allowing you to use a higher fuel grade such as C16/Q16. For most applications c16 will cover your fueling needs up to 1600whp depending on application of course. After that you would look into using a NOS max fuel with higher octane. C16/Q16 are fuels you could go with to feed the fuel solenoid of the system to keep detonation to a minimum, increase ignition timing thus allowing you to make more power. Some people will use E85 but you should always test the Ethanol content of the fuel before using it. Most places that have E85 have winter and summer blends resulting in amount of ethanol not meeting advertised content. For instance the winter blend in Texas usually tests out between 70-75% ethanol. Of course that is not 85%. If you have any questions feel free to call me or PM me 254-848-4300 EXT 109 -Houston
